Old 07-30-2019, 10:04 PM   #1401
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Rich Biebel View Post
I’ve never seen or used those pin locks.
My own engine in my dragster has Diamond pistons and spiral locks the std. used for many years. Single or double and I’ve never had one break or come out.
It was s.o.p. to verify the pins had some clearance or movement between the locks. Every piston I assemble, I check to be sure the pin can rotate freely in the piston without binding on the locks.
Obviously something way wrong with the lock, piston, pin arrangement.
That was a real bad mess and should not have happened given they were all good name brand parts.
Years ago we used a snap ring type pin lock. Spiral locks became the normal lock usually used. The locks tend to dig into the groove and raise up a burr but unless they were not installed right, rarely failed.
Very ugly mess. I’ve seen plenty of blown up engines. It’s never pretty and always expensive.
Sorry to see it ....
Rich, these Diamond pistons were built for a snap ring style (from Diamond) and had the corresponding pin for the snap ring style lock (they're different).
Todd Greene
Old 07-30-2019, 10:38 PM   #1402
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Yes Todd I would assume all those parts were made and machined to fit together and work properly.
Will be interesting to hear what feedback you get from Diamond.
Rich Biebel
S/C 1479
Stock 147R
Old 07-31-2019, 08:01 PM   #1403
Nmbr1GMfan
Got the heads apart today #3 chamber took a nasty hit. Have a few bent valves so I'll order a whole new set tomorrow and hope we have room to surface the head into good working order. Diamond has reviewed the pistons and believes there's a problem with the way the groove was machined, they're investigating further but in the meantime they'll expedite a set and get them out at no charge. Still waiting to hear back from Titan about oil pump fitment but I believe I'm going to cut my junk pan up and take some measurements.
Todd Greene
Old 08-01-2019, 08:14 PM   #1404
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Todd,
Make sure you check that head for cracks. If they have been milled quite a bit to get the right cc's they can crack easily from a piston or valve hit.
Mike Moller
NHRA 203 Q-R-T/SA
MikeMoller is online now   Reply With Quote
Old 08-01-2019, 08:57 PM   #1405
Nmbr1GMfan
Originally Posted by MikeMoller View Post
Todd,
I'll be pressure testing the head, I'll post up some pictures of the process. Should be a new learning experience.
Todd Greene
Old 08-01-2019, 09:03 PM   #1406
Nmbr1GMfan
Block is here, rods are here. It's groundhog day!
Todd Greene
Old 08-01-2019, 09:28 PM   #1407
Rod Greene
Liked 242 Times in 81 Posts
DEJA VU all over again Reading your posts I have learned way more than I ever wanted to know about a Cheby. Wish we could get blocks for our Mopars in 2 days.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 08-01-2019, 10:09 PM   #1408
Nmbr1GMfan
I don't know much about a Mopar, and at this point I know more about machine work than I ever wanted to, but yes, Dart really came through with the block. We have plenty of work to do I'm guessing till mid next week.
Todd Greene
Old 08-02-2019, 02:54 PM   #1409
Nmbr1GMfan
Cams are expensive... That is all.
Todd Greene
Old 08-02-2019, 10:01 PM   #1410
Nmbr1GMfan
I feel like today was a pretty good one, crank came in, lifters came in and the "cam guy" is on board with my ridiculous schedule. Got all 8 holes bored today and got it on a stand.
Todd Greene
