Old 12-26-2020, 06:56 AM   #111
Liked 10,786 Times in 2,242 Posts
Default Re: The "eBay CJ!" (2010 Mustang CJ 352 Build)
It’s been a while since I looked but you might want to check weight box bolt size and number for the top. Everything looks great! It will be one cool ride.
Old 12-26-2020, 09:35 AM   #112
Billy Nees
Liked 7,790 Times in 1,744 Posts
The size looks OK but I think that you'll need 8 3/8ths bolts in the top. Also, no more than 100 lbs. including box.
Billy Nees 1188 STK, SS
Old 12-27-2020, 05:41 PM   #113
I'm sorry but the rule book 2009 makes no mention of size or number of bolts to hold the top of the box on. I thought it did. Just old age playing a trick.
Old 12-27-2020, 06:18 PM   #114
Billy Nees
Don't feel too bad old man. My 2015 rule book only says 1(one) 3/8 bolt for each 5 lbs. of ballast. I'm only going by "aftermarket" boxes that I have in my shop.
Old 12-27-2020, 07:24 PM   #115
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I looked at the 2020 rules online, didn't see anything about size, or bolts, other than 1/2" bolts for mounting to car. My weight box is a Ford Racing part, I have seen it on many CJ cars.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 12-27-2020, 08:01 PM   #116
JHeath
JHeath's Avatar
Larry, you and Billy aren't wrong, this is from 1998 NHRA rule book, that was when I built my 89 Mustang stocker, I made a box with 6 bolts holding the cover on, this isn't in the more recent rule books.
Jerry Heath
I/S '93 Cobra
Old 12-27-2020, 08:18 PM   #117
JHeath
JHeath's Avatar
Covered up the package tray with some .032 aluminum, that finished the trunk, other than wiring. put the hood on and drilled for the hood pins. installed the bumper cover, upper and lower grilles. installed the snaps for my "Classic Coverall" from MJ Quinn @ Derby City Covers, and attached it to prevent damage while working under the hood.
ID:	56531   Click image for larger version
ID:	56532   Click image for larger version
Name:	Classic Coverall.jpg
Jerry Heath
I/S '93 Cobra
Old 12-28-2020, 07:47 AM   #118
Thanks Jerry all of my boxes that I made use six 5/16 bolts for the top. I wonder why NHRA deleted the drawing? The drawing gives everyone a road map for a safe weight box.
Old 12-28-2020, 09:28 AM   #119
JHeath
JHeath's Avatar
Larry, it was in the 2002 rule book, I am missing the 2003, it isn't in the 2004 , so either 2002 or 2003 must have been the last time it was in there.
Jerry Heath
I/S '93 Cobra
Old 12-28-2020, 12:46 PM   #120
I suppose that weight boxes started showing up in many different shapes and sizes.
They decided to just go with what looks reasonable.
A dozen 1/4 x 20 bolts would probably work , but too much hassle.
