Old 05-20-2021, 07:14 AM   #1
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Question 12 Bolt Pinion seal leak
I have a 68 Chevelle (original)12 bolt and the pinion seal leaks. New seal installed however there is a groove in the yoke. Does anyone have part # for a speedy sleeve or is it best to replace with aftermarket yoke? If so what brand and part # is the best??
Thanks in advance
The more people I meet the more I like my dog
Kevin
Old 05-20-2021, 07:45 AM   #2
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Default Re: 12 Bolt Pinion seal leak
My 12 bolt pinion seal was also leaking. Replaced the seal twice, still leaked. I found out that it was leaking around the OUTSIDE of the seal where it meets the housing. Housing was pitted pretty bad, so I ended up putting some RTV sealer around the outside of the seal before installing yet another new seal. That finally fixed the leak. You may want to look at that area on yours to eliminate that as the leaking area.
NHRA1926 is offline   Reply With Quote
Old 05-20-2021, 07:51 AM   #3
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Rock Auto has the yoke and repair sleeve.
USA STANDARD GEAR USA41152 Info
Rear Differential; GM 12 Bolt Passenger Car; Rear Pinion Yoke; U-Bolt Style; For Use w/ 1330 U-Joint; 1.063 in. Cap Diameter; 3.625 in. Span; Cast
$197.79
USA STANDARD GEAR USA41154 Info
Rear Differential; GM 12 Bolt Passenger Car; Rear Pinion Yoke; U-Bolt Style; For Use w/ 1350 U-Joint; 1.188 in. Cap Diameter; 3.625 in. Span; Billet Steel
$253.79
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 05-20-2021, 11:01 AM   #4
prostockpete1
Liked 90 Times in 52 Posts
If you just want oem quality Dorman.com has pinion yokes and thinking most parts stores / Rock auto have
prostockpete1 is online now   Reply With Quote
Old 05-20-2021, 11:31 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Kevin,
If yours is the 1310 series with the straps.. I have a brand new Spicer that has been on the shelf 40 years.
call me
903 824 4924
Adger
Adger Smith (Former SS)
Old 05-20-2021, 12:22 PM   #6
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: 12 Bolt Pinion seal leak
Ive had trouble with a leaky pinion seal on 12 bolt. Finally I started putting a little rtv in pinion threads before I slid yoke on pinion. No more leaks.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 05-20-2021, 07:11 PM   #7
Dana Fitzpatrick
Liked 10 Times in 6 Posts
I use a Ratech #6109 seal or the equivalent Strange part number.It puts the seal at the correct position on the yoke, most other seals do not and a leak will be the result.
Dana Fitzpatrick is offline   Reply With Quote
Old 05-21-2021, 08:37 AM   #8
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Bill is correct, the pinion splines will leak gear oil out and fool you into thinking that the seal is leaking. I use the white liquid Teflon thread sealer with great results,
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 05-21-2021, 10:49 AM   #9
Bill Grubbs
Liked 564 Times in 66 Posts
Just use Ultra Grey in the well around the pinion nut. No leaks from the splines, and the nut will never ever move. no fuss...no muss...no leaks from the splines...no staking the pinion nut...and you can reuse the nut over and over. We are now on the 20th year on the nut, never a leak from the pinion splines, and never a loose pinion.
Warning!!! Don't expect to put Ultra Grey on and race immediately, you will have a mess. Let it set up over night before use. Also, it will take a few minutes to get the Ultra Grey off and remove the pinion nut. However, a wire wheel on a drill will clean the nut, washer, and yoke right up.
Bill Grubbs is offline   Reply With Quote
Old 05-22-2021, 07:57 AM   #10
SSGN
SSGN's Avatar
Thumbs up Re: 12 Bolt Pinion seal leak
Adger thanks for the offer but the big block has the 1330 U-joints. I pulled the shaft and checked. We always use the ultra grey on the splines also. I am looking at the Dennys stuff right now.
Thanks for the info,as usual a wealth of knowledge here.
Kevin
