#11 |
Liked 80 Times in 44 Posts
Are you doing dyno work in Texas? Little River has a lot of history.
#12 |
Liked 281 Times in 108 Posts
Just a brainstorm about the truck project. You could fine a short bed and convert the truck to a shorter wheelbase with a one-piece driveshaft.
#13 | |
Liked 372 Times in 129 Posts
a option if I can find someone I trust. Last edited by HP HUNTER; 10-11-2023 at 10:29 AM. |
#14 |
#15 |
So I started my 350 build, .060 over 2 bolt 010 block, I did some work to the factory cast crank which ended up @ 3.483 stroke, I put a 6 inch rod in there with a + 6 cc dome Mahle piston, my Fuelie heads came in at 74 CCs which gave 10.8 compression. My solid lifter cam was .528 lift @ the valve with 264 @ .050 duration on both sides, 108 lobe separation. I used a Performer RPM intake with a 750 Holley, the Moroso pan was modified.
#16 |
A picture of my new 350
#17 |
The 350 with 4 passes delivered the following performance in street trim with the power steering and steel two piece drive shaft @ 3970.
1.50 60 foot 7.04 660 @ 94.2 MPH https://youtube.com/shorts/aS_Mx_tTz...4QheGAyGXu5mMu More to come............. |
#18 |
Which track is the video?
#19 |
Liked 10,738 Times in 2,234 Posts
You truck looked and sounded very good on the track. Congratulations
#20 |
