#21 | |
Liked 805 Times in 341 Posts
Just out of curiosity, what does the Accutime tree look like when there is a staging timeout? Bill |
#23 |
Liked 232 Times in 69 Posts
I've heard that the track in Dallas also has had similar issues in the past. Does anyone know if they use the same timing system as Dallas at No Problem Raceway?
#24 |
Liked 425 Times in 51 Posts
It happened to me also in the class race Friday we both staged when the first yellow came on mine went red ! My son was videoing and my car never moved! Went to the tower and they said we could rerun it both agreed. We did with no problem the second time.btw I was in the left lane also.
#25 |
Liked 1,144 Times in 354 Posts
I made nine runs in the left lane with no problems, no pun entended, except 1st round eliminations on Saturday -002 and the car made a left turn at launch, got home.put the car in the air, nothing wrong with the car.
Randy Wells I/S 5628 Last edited by Randy Wells; 03-18-2025 at 08:02 PM. |
#26 |
Liked 997 Times in 201 Posts
A very similar thing happened a few years ago at the Fall Classic Indy on sunday morning. The instant the tree started down on one side that racer got a red light. It happened to several cars in a row. All foot brake racers. Of course the division director at that time was no help, and several racers went home very unhappy. One racer I knew who was a victim never raced at another NHRA race.
#27 |
Liked 135 Times in 74 Posts
Stage lock. I always wondered how this worked and never received a complete answer. Supposedly if you flicker the Stage bulb a couple of times it will lock the stage bulb on. If this is the case then my assumption is you could not be staged. And if prestage light is on, you did not pull thru the beams, leave early. Any input appreciated.
#28 |
Liked 36 Times in 26 Posts
Years ago I would always go up and looks at the beams and sensors when the would take the lid off so you could see. Stage lock has four sensors, you need to check your track to see if they have it. Talked to the nhra guy at the time , you roll back out of the stage light the stage lock will keep the stage lite. You need to figure out if they had it or not..
#29 |
Liked 181 Times in 56 Posts
I was watching on YouTube when the Hidalgo/Neely race was run. It appeared to me the dial ins were in backward. Hidalgo's tree came down and Neely moved when Hidalgo did and went red.
I am old and may not have seen what I saw. Something was up though, there were a few runs that the left lane was red and the timing graphic showed Left Before Tree Activated. |
#30 |
Liked 50 Times in 15 Posts
I've established a dialog with the D4 Director about the timing system problems and will provide an update once a conclusion is reached. JJ is a good Director/Manager and I'm optimistic he will ensure that racers are treated fairly whenever issues like happen.
Ron B. |
