Old 06-29-2008, 01:19 PM   #51
bighead
bighead's Avatar
Question Re: Was it just me?
Jeff:
If there is a technical issue at our local track or a divisional race, do they have the availability to check for lazy infrareds or other posibble irregularities? For instance at a division 5 race there were approx two hundreds difference between lanes, react and e.t., and some people new that while others like me were left to think there were t-stop issues or chassis probelms. Without looking like a cry baby what does a racer do when they tell you there is no timing or track problems? Thanks again or all your technical input.
Craig Anderson
bighead is offline   Reply With Quote
Old 06-29-2008, 01:40 PM   #52
Jeff Foster
Default Re: Was it just me?
Craig at D5 take slips to DD, Rob is good at checking things out and not affraid to call me.
Jeff Foster is offline   Reply With Quote
Old 06-30-2008, 04:27 PM   #53
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Hey Jeff....can you pm me with the brand names of the photoeyes....I will investigate some testing methods....maybe we can come up with something easy that you can do each morning...so you can fix them before the race....
Rock Haas
CBS is offline   Reply With Quote
Old 06-30-2008, 09:03 PM   #54
Jeff Foster
I've been in this buissnes for 15 years our company 28 years, our IRs are custom built for us, we know all there is to know about them. They are tested and checked at the start of events but unless you can come up with something that replicates the vibration and harmonics of a car on the convertor at 5000+ RPM, we probably allready have it.
Old 06-30-2008, 09:55 PM   #55
63corvette
Liked 362 Times in 105 Posts
Jeff, all those years of experience is good for one thing The Experience. If something new needs to be done to level the playing field for everyone lets try something new. Do Not Defend Something Just Because It Has Always Been Done That Way!!!!
My 2 Cents
63corvette is offline   Reply With Quote
Old 06-30-2008, 10:03 PM   #56
Ruth
Maybe mounting them on on something like this to test them could replicate close to what your asking for?
Ruth is offline   Reply With Quote
Old 06-30-2008, 11:11 PM   #57
CBS
CBS's Avatar
I wasn't trying to fault anything you have been doing.....I just thought maybe the manufacturer might have a piece of test equipment that measured the speed and repeatability of the eye....but in place at the track...
this situation rarely happens...but in the case @ Joliet...it sounds like its been there for a while....surely you checked the eyes there and they passed your procedure....otherwise you would have changed them....
maybe we can provide you with a car when you check them to simulate some vibration....I'd sign up for a morning....I'm sure we could get enough volenteers....
We all know Compulink is the finest....but if we can help to make it better...we are all interested...
Just so you know where were coming from.....
When we spend what we do to do this "Hobby"...and travel x amount of miles....and can't cut 2 lights within 4 hundreds of each other....because something might be failing on the timing system....
makes us unhappy...
So if we can help in any way....to make the system better ....let us know....there are all kinds of characters on this site....engineers to floor sweepers ...I'm sure...maybe somebody can help....
Rock
Old 07-01-2008, 10:47 AM   #58
Jeff Foster
I was not, as stayted "Do Not Defend Something Just Because It Has Always Been Done That Way!!!!"
I was just statting we work with the manufacture of our IR sensors to develop and have them custom built, they arent off the shelf units. We have all equipment available to test them, but things change with the harmonics of the cars that cant be seen in the testing.
Old 07-01-2008, 11:00 AM   #59
CBS
CBS's Avatar
Is there anything we can do to help you...if there is don't hesitate to ask....
CBS
Rock Haas
Old 07-01-2008, 12:07 PM   #60
shooter66
Just wanted to let everyone know that RT66 replaced the IR on the left lane stage beam, and tested with cars that said they had problems with it and the showed everything is now good with the startline.
Jeff Foster
Hey thats awesome news thanks Jeff!!!!!!
shooter66 is offline   Reply With Quote
