Liked 332 Times in 180 Posts
Why not run a -12 then you will have as large a line as you may ever have a need for---can't hurt better to big than too small right??? Too big definately will not hurt it while too small and you will always have problems---Comp 387
What about G forces trying to make the fuel flow backwards if the line is too big? I started using braided line, but switched to the pushlok stuff, I think its easier to use. I use -8 an to feed 650hp or so.
*** 72 Malibu *** 1.329-3.99-6.28@106.71-9.98@131 best 60ft to date-1.2997 |
put 2 pumps on it with a bypass to return any unnecessary fuel to the tank!!!!!!!!!!!!!!!!!!!!! I hardly believe that G forces of any significant amount come in to play here on a Stocker or S stocker----Comp 387
Liked 1,877 Times in 577 Posts
not as pretty, but aluminum line is a lot cheaper. run to punp, then nice braided.
look on Ebay and get some left over or used from a Nascar team probably for 25% of new-Its your car do it however you want I know what I'd do and it would not be aluminum line!!!! comp 387
Aeroquip Socketless hose.
A lot cheaper than braided, approved, reusable ends, & easy to work with. I use it on my entire fuel system & radiator hoses on my bracket car. Good Luck!!
Steve Obertanec |
