Old 04-24-2011, 01:02 PM   #4
Kenney Kelley
Liked 72 Times in 36 Posts
Default Re: Front Disc brakes are a "drag".......
The master cylinder is a good place to start looking . I also found the hoses going to the calipers and the one going to the rear end might look good on the outside but are plugged on the inside. We also changed the master cylinder and removed the stock proportation valve and replumbed the lines and that fixed our problem. I know this sounds like a lot of work but being able to stop on a short track is priceless. Kenney Kelley
Kenney Kelley is offline   Reply With Quote
