Old 05-21-2012, 06:50 PM   #1
jmdavison
jmdavison's Avatar
Liked 16 Times in 6 Posts
Default Re: stock GM front disc brake spring kit
Check Raybestos, they have a spring for some applications...
jmdavison is offline   Reply With Quote
Old 05-21-2012, 07:01 PM   #2
Mike Fuller
Liked 203 Times in 80 Posts
Die springs work well. You have to do a minor mod to the pads. If we both end up at Joliet I'll show you what I mean.
Mike Fuller 396 STK
3961 SS
Old 05-22-2012, 05:30 AM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
ya know, i've heard of this for year BUT have yet to figure out where the spring could possibly fit to take the drag out of the pads... can/will somebody enlighten me?
Old 05-22-2012, 07:40 AM   #4
Dennis Banach
Tom,
The springs go in between the pads on the guide pins.
I ran `69 Camaro in the `70s with Factory disc before converting to drum fronts,I used the preload springs from a 12 bolt posi unit with a 7/16 washer on each end of the spring.
You do need to keep an eye on pad wear and change them if they get close to coil binding the springs.
I ran a full season with that set up and never had a problem.
Dennis Banach is offline   Reply With Quote
Old 05-22-2012, 08:54 AM   #5
Tom keedle
Tom keedle's Avatar
ahhhh, NOW i get it!
ain't gonna help me though, got ford type (think mustang II) calipers on the rambler...
Old 05-22-2012, 11:28 PM   #6
Dan Nugent
Liked 3 Times in 1 Post
I found some springs at the local hardware store that had a spring assortment. Used ones that fit the guide pin close, just enough tension to let the rotors turn freely.
Dan Nugent is offline   Reply With Quote
Old 05-23-2012, 01:10 AM   #7
Good point..Too much spring, not enough pedal (on the first pump)
