#51 | |
#1 100 LBS is worth about a tenth down to about J-K-L. Lower than that, 100LBS is more than a tenth. Higher is less. Results may vary based on combo. #2 Doesn't even deserve an answer. Too much speculating and assuming, and you know what assuming does, don't you? #3 If you're going to go 10.90 racing or Bracket racing, that's fine. I won my first Division Championship 10.90 Racing and I've done very well for myself Bracket racing over he years BUT it's NOT Stock or SS racing. That takes a certain amount of dedication and commitment that a great deal of racers aren't willing to make. #4? Most of us on here know all about what it takes to go 10.90 racing. If we cared to do that, then we would. This is a Stock and SS board. Again, I will suggest, get a car that fits your parts or get a car. It is seeming to me that the cheapest, easiest way for you to wind up in something like a Stocker would be for you to put a 350 2V combo in your Ventura and sell your 455 stuff to finance it. My .02.
#52 | |
Liked 747 Times in 362 Posts
But I realize that with a high stall, max gear, light tranny with a 2.75 low, right cam, etc, etc, it will go a lot quicker. I reckin my main concern would be the 2-barrel. I can see how they might supply a 301. But I'm not sure they would supply a 13 sec 350. But I'm sure you've had a lot of experience with 'em. So what is the quickest time you've seen turned with a low comp 350P 2-barrel ? I suppose what I need to do is learn all I can about a 2-barrel for racing. So, is this something that most anybody can do ? Or is it best to just come up with the $ and buy one from somebody who knows all the tricks. I reckin a better way to ask the question is, can I just do some simple jet and other minor changes, along with a good rebuild and tune, or will it require detailed internal mods done by a 2-barrel racing expert ? Anyhow it's another option. And since this is a fact finding thread, I'll try to dig into it a little deeper. So, any of you guys reading this who have had success racing a GM 2-barrel similar to the one I'd have to use on a '74 Vent 350P engine, please post all the info you can share about it. I need info like what cubes did you run, what was the weight of your car, how many rpm did you turn, cam specs, stall speed, rear gear, ET, and anything else that might relate, in particular to running a 2-barrel as compared to running a Q-jet. I'll ask a simple question which probably has a complicated answer. On very similar engines, with each combo maxed out, about how much quicker will the Q-jet car be, than a 2-barrel car? Hey, I know it's a dummy question. But if I knew the answer, I would not ask the question. ![]() |
#53 |
So, if I tried to convert my Vent to a Stocker, I'd have a lot of changes to make. As you can see below, it has nice bars, but the dash has been replaced with sheet metal. And it has ladder bars, which would need replacing with Cal-Tracs or at the very least, homemade slappers.
Also would need a stock hood, front bumper, and I'm sure, lots of other stuff to make it pass tech. So, I might come out better trying to find a decent stock body, and start from scratch. That's the reasons I haven't considered it as a potential Stocker. |
#54 |
I do like the idea of racing with leaf springs. They are just so much simpler to deal with. So that leaves a choice between a Bird or a Vent. I really prefer a Bird. But I like Vents OK too. And I figure a decent Vent body will be a bit cheaper than a decent Bird body.
So, if I don't use my '74, for the reasons mentioned, lets explore the other possibilities. The 350P was not used in a '71 Vent. It was used in '72, but is factored at 250hp. So that's no good. But in '73, it was used and is factored at 210hp. Also, the '73 model is the last year that NHRA allows 350P pistons, with valve reliefs, according to the info on the link below. The '74-'77 350 pistons are absolutely flat--no reliefs. http://www.classracerinfo.com/Engine...px?ENGINE=2071 The old TRW forged piston # L2339F is legal for the '68-'73 350P. They quit making these a long while back. But you can occasionally run across an NOS set. I have 2 sets. One in the box and one in the 350P shortblock that came out of the 350HO Tempest I mentioned. The oil was milky in it, and I had no use for it at the time. So we never even tried to find out how the water was getting into the oil. It and the other 350 pistons are still over at my engine guy's place. There is also one high dollar piston that was approved over a year ago but is not on the list at the above link. It's a CP brand # P5-CP. This site shows that both it and the TRW 2339 are legal thru '74. So there is conflicting info there, between the 2 sites. But since the site linked below is an official NHRA site, I'll go by it. So, according to it, the '74 models can use any of the approved pistons for all years of the 350P, from '68 thru '77. This info can be found on the bottom of page 60 and the top of page 61 at the link below. http://www.nhra.com/userfiles/file/N...edProducts.pdf The 350HO shortblock I mentioned just has stock, cast rods in it. But in a 350, they should be good to at least 6200-6500rpm. I don't figure a 2-barrel 350 will pull any higher than that. I don't have any #46 heads to put on it. But I do have a good set of 6x heads I could use on it for testing purposes. I could find out if I can get a 2-barrel 350 to run under, without buying a set of cores and paying for the head work. My engine guy has a 350 block with 8 sleeves in it, that he was going to use for a serious dirt track project. But all the tracks in our area shut down. So, I could use my NOS TRW pistons and his 350 block, and build up a strong 350 shortblock. Hey, I'm just sorta thinkin out loud. I reckin that's the way a lot of low buck guys do it--think of all the parts you have available and figure what you can put together. I've got a 2-barrel on a '71 455, that came out of a Safari wagon. I wonder if that would pass tech on a '73-'74 350 Vent ? By the way, this same engine is legal in a '73-'74 Bird and lots of other models. Any more comments on the possibility of running under with a '73-'74 350 2-barrel engine ? Last edited by oldskool; 01-19-2015 at 06:45 PM. |
#55 |
On E-Bay right now there is a 75 Bonneville 4Door with 10K orig. miles on it. It's a 400 4V and it's in Oklahoma. $3995 buy it now price.
It's big and it's ugly but it's complete, running and doesn't need any paint or body work. It ain't gonna get much cheaper than that in this day and age.
#56 |
Thanks for the info Mr. Billy !
But if I'm gonna buy a big heavy 4-door, it'll have to be a wagon. And since I already have plenty of motor parts and trannies, all I need is the correct year body. I think I can find just a usable body in my area for $1000 or less. I reckin I live in an area with a very depressed economy. If you can get to a car before some wineo or scrap dealer takes it to the crusher, you can find some real bargins. ![]() I was cruisin thru the 455 hp factors again lookin for the best possible combo. What I found that looks better to me than any other combo is a '73 Formula with a 250hp 455. It's factored at 306hp, if this info is correct. http://www.classracerinfo.com/Engine...px?ENGINE=2079 Since they all look very similar from '70-'73, any of those years will work, as a '73. Some of the '70 Formulas and TA's had a 12 bolt rear end. Then all the '71-73's should have the 8.5" ten bolt. Last edited by oldskool; 01-19-2015 at 10:44 PM. |
#57 |
Liked 5,134 Times in 1,958 Posts
Nah..Don't like the 2bbl..You'll cut too many corners and it won't run the index.
Besides, the car is too far gone..Needs too much.. I was going to suggest a 74 GTO SS combo @250 hp..Build it like a Stocker, but with a flat tappet cam and an Edelbrock intake. It ought to run under the SS/MA, 11.85 index You realize you get 3 more tenths index with IHRA..Might be the deal for you. But here's what you need to do with what you got. Take that big 80's wagon and put it together as a 77, 400/260 for P/SA. Put an .88 gear in it and a low gear T350. If it runs good, then change the front panel and the tail lights to 77 Use your 6x -4 heads. We can steer you in the right direction with them. Find an 8 " converter in the pile,..and I can get it handled for you Hey , good, free advice is sometimes hard to come by. I realize I'm bumping up against the commercial side here, so better save this post LOL ;-)
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 01-19-2015 at 10:26 PM. |
#58 |
Yeah, I like the looks of both those combos. But on the GTO SS deal, I'm figuring that because of all the noise Bill Rink has made with it, that it will soon get hit with a big refactor.
![]() Now, about the wagon. You think it is close enuff to a '77 to convert and pass tech with it ? ![]() Last edited by oldskool; 01-19-2015 at 11:19 PM. |
#59 | |
The tail lights, and the rear bumper.. The VIN is irrelevant.
#60 |
OK guys, I need some help here with some info that may help me and others. I just got involved in a tranny discussion. The OP wanted to know which tranny to run behind his 700hp Pontiac, a TH400 or a Glide. He was afraid the Glide would slow him down. I suggested a TH350, and posted 3 links with TH350's rated at 800hp +.
But one guy basically said the TH350 is junk and won't stand 700hp. I even posted the link of a guy telling about his Turbo Action TH350 that had held up for 3 seasons with 1000hp. But there are a lot of unbelievers. I assume that lots of you SS guys are running TH350's with somewhere in the neighborhood of 700hp. So I need posts that I can copy and paste, with some of ya'll telling about your sucess with a SS TH350 tranny. So, can anybody give me some directions on how to find such info on this site ? Thanks ! ![]() |
