#1 | |
Liked 747 Times in 362 Posts
OK, you said the odd ball rear began in '77. The '76 Lemans wagon has the same 116" wb. So does it share the same rear as any of the other '73-'77 models ? 8.5 but wider ? And if so, is there a possibility that the '76 wagon rear may have the big brakes and bolt-in axles you mentioned ? ![]() Last edited by oldskool; 01-29-2015 at 04:47 PM. |
#2 | |
Liked 61 Times in 25 Posts
Cut the axle tubes and widen them if that is the car you want to build.
#4 | |
![]() Last edited by oldskool; 01-30-2015 at 02:44 AM. |
Liked 33 Times in 16 Posts
REAR END
Original rear end may be replaced with another from the same automobile manufacturer; truck rear end prohibited. Aluminum center section permitted only on vehicles that were originally equipped with same." Distance between backing plates may not be changed." Any gear ratio that fits third-member case or housing permitted. Limited-slip or ratchet-type rear ends permitted. Reinforcement of spring perch permitted. Spools permitted only with aftermarket axles. Aftermarket axles not required for front-wheel-drive vehicles. Larger brakes may be used." Replacement rear end may be narrowed or widened to obtain original rear-end width." Bracing or beefing up the rearend housing permitted.
Rich Taylor I/SA - 321 |
#6 | |
Again, that's just country boy thinkin. I've never raced a Stocker at the division level. But I've recently read that unless you set a National record, there are no tear downs. So, I reason that if no tear downs, certainly they wouldn't care if your rear end was a couple of inches too short. Is that a reasonable assumption ? |
#7 | |
#8 | |
I only bring this up because of your questioning if someone will measure a differential or not. When you are the "new guy on the block" there will be more attention paid than you can imagine. Look up the thread where Toby Lang blasted a competitor for "testing" an illegal carb during qualifying and tell me wrong parts don't matter. Wrong is wrong doesn't matter what $$ state a person is in. I am not a rich man and probably have a car that is not ideal for its class but I run it and run it hard, it took 8 years for the car to come around. Because of the effort I put in my car,If I become aware of a fellow competitor running illegal your damn right I would protest that, the same I would expect to be protested if I was illegal. my $0.02 take it for what you will.
Dion Hildebrandt 6009 STK H/SA |
#9 | |
Liked 240 Times in 112 Posts
My Cougar has a 9" in it but I have had a mini spool in it for years. Moser said it would be plenty strong. When I recently changed gears, I got another one from Jegs. It had 4 hole's in it for use with the 4 spider diff's.
Dave Noll, EF/S ,?/SA 6526 |
#10 | |
I really can't imagine shearing a pin with a slow footbraker. We made hundreds(or maybe well over a thousand--didn't keep track) of passes with our 455 bracket cars, using mini spools, without braking any part of the rear. But, Tony said he's seen the carrier cracked, when using a mini. ![]() Don't know if your 9" carrier is thicker and less prone to cracking or not. |
