Jim, Have you ever tried radials on a stick car?
I have, and it wasn't pretty.
Liked 1,438 Times in 301 Posts
Yes.
James Schaechter 3163 STK |
Tell you my story first then.
About 20 years when the Hoosiers first came out, I tried a pair on my 400 4 speed Firebird .Can't remember why I did it when I did ,but it was the first round of a Divisional. They hooked real well .In fact so good , I split the pinion flange in half right on the line. Of course the red light was on in the other lane, but I couldn't come back for 2nd round. A few months later at Bowling Green before Indy , I was having trouble with initial hook up. I borrowed the same tires again, wanting to see what it would pick up on the other end. It left fine but then started bouncing up and down thru low and most of second. I was determined to run it thru the lights so I didn't lift .Right before the 2-3 shift it jumped right out of gear. I went back to the pits, returned the tires, and never again tried radials on a stick shift.
Liked 53 Times in 16 Posts
The 4 Cylinder deal could work too. Years ago my buddy Pat Henneberry bought a 1985 Camaro that came with a 151 "Iron Duke" Pontiac w the fuel injection. I looked it would fall into W/S with 24.36 factor and HP NHRA rated 115. We disconnected the exhaust took it to Island Dragway just to see. If i remember it ran 18.60 than we swapped out to a smaller diameter tire and picked up 3 tenths to a 18.30 This was totally stock with an automatic. That 200R4 i think. I would like to believe those were 17's but they were probaly 18's . Hey , he still has car. That motor has a hydraulic roller cam too! Small block 5.70 rod. 16.40 index.
Will Lamprecht |
