Old 11-07-2015, 01:06 AM   #1
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Default Re: Ground up build Chevelle
Off to the sandblaster and the start of body work. I removed EVERYTHING from the body...seamsealer,under coat etc. Bare metal blank Canvas.
ID:	31606   Click image for larger version
ID:	31607   Click image for larger version
ID:	31609   Click image for larger version
ID:	31610   Click image for larger version
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 11-07-2015, 01:12 AM   #2
stocker396
stocker396's Avatar
After sending the body to get powder coated ( I did not get a picture of it after that was done it was off to "Deluxe" to get it straightened out. Also pictures of the frame before, after we boxed it it, and reinforced it for the roll bar.
ID:	31612   Click image for larger version
ID:	31613   Click image for larger version
Old 11-07-2015, 01:19 AM   #3
stocker396
stocker396's Avatar
The Frame is back from powder coat and things are getting ready to get pretty....
ID:	31616   Click image for larger version
ID:	31617   Click image for larger version
ID:	31619   Click image for larger version
ID:	31620   Click image for larger version
Old 11-07-2015, 01:23 AM   #4
stocker396
stocker396's Avatar
The color of choice has been selected. The original owner of the car made me promise to "never paint it some gaudy awful color or put silly flames on it" LOL. Factory Mist Blue Metallic....unfortunately VERY expensive.. to be continued......
Old 11-07-2015, 11:40 AM   #5
stocker396
stocker396's Avatar
After the frame came back it was time to put on some pretty stuff.
Went with ALL Strange Engineering components. 12 bolt (all Lite) Front and Rear 4 piston disc brake system. Global West bushings, Spohn Rear Arms and Anti Roll-Anti Sway Bar. moroso Trick springs (to start) QA1 Stocker Stars out back and CE' up front. This will be the start point as I am sure I some stuff will change later.
ID:	31623   Click image for larger version
ID:	31624   Click image for larger version
Old 11-07-2015, 11:43 AM   #6
stocker396
stocker396's Avatar
Now this is the Base Coat. Its weird how the lights affect it with out clear on it.
ID:	31627   Click image for larger version
ID:	31628   Click image for larger version
ID:	31630   Click image for larger version
Old 11-07-2015, 11:47 AM   #7
stocker396
stocker396's Avatar
Now its Shiny again! Special Thanks to the Howard Brothers for this part! Stopher and Matt put alot of work and detail into this for me. They normally work on only high end european stuff.In these photos you can really see the contrast between the powder coat silver and the blue paint
ID:	31632   Click image for larger version
ID:	31633   Click image for larger version
ID:	31635   Click image for larger version
ID:	31636   Click image for larger version
