Old 09-03-2017, 05:36 PM   #6
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Default Re: Help from Cobra jet owners/drivers front suspension
I shortened my front lower control arms by 1.5 inches. The bracket that holds the lower ball joint can be removed by using a cut off wheel to grind out the weld. Then cut the arm off 1.5 inches and place the ball joint assembly back in the channel and weld it back in. You will also have to shorten the tie rod end and the rack end. The picture shows my old drivers lower control arm next to the shortened drivers control arm. I now have 0 degrees camber with the wheels tucked under.
ID:	42058   Click image for larger version
ID:	42059   Click image for larger version
ID:	42061   Click image for larger version
ID:	42062   Click image for larger version
ID:	42064   Click image for larger version
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
