Old 04-23-2018, 11:36 AM   #301
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by FED 387 View Post
try NUT shells ---pecan/walnut something like that if you can find it---they are hard enough to clean the rust/crud off yet soft enough without damaging the metal--- plus they are cheap--- try a landscape place see if they have some
Thank you, I have to find something because my blaster is too big and blows everything into next week.
Todd Greene
Old 04-23-2018, 03:08 PM   #302
FED 387
Liked 335 Times in 182 Posts
Try a piece you really don't care about with pea gravel that works pretty good sometimes too
Old 04-23-2018, 05:49 PM   #303
Nmbr1GMfan
Thanks, This stuff didn't work either. I have most of this stuff new, but I figured I'd clean it up just in case.
Todd Greene
Old 04-24-2018, 07:39 PM   #304
Nmbr1GMfan
Did some blasting and coating this afternoon. Pedal assembly, some brackets, door handles and trim. Of course I couldn't resist stopping by the shop on the way home to see what it looked like.
Todd Greene
Old 04-25-2018, 09:17 AM   #305
Alan Nyhus
Liked 800 Times in 237 Posts
Will be killer good looking, for sure. -Al
"That'll never work....."
Old 04-25-2018, 10:20 AM   #306
J&S Racing
Liked 327 Times in 87 Posts
Door handle looks killer!!!
Thought about blacking out handles, bumpers and window trim on mine...
Old 04-25-2018, 10:38 AM   #307
FED 387
just thought of another way to remove rust on small parts--antique guys use white Vinegar-Vinegar is really a very weak acid----soak it overnite fully submerged---depending on how bad the stuff is might take a time or 2 to do it---DOES NOT remove paint or other crud just rust then rinse with water and blow dry or put it in the oven or sunlight to heat it up and dry any moisture you might have missed in the blow drying
Old 04-25-2018, 11:27 AM   #308
Nmbr1GMfan
Thanks, Al.
Todd Greene
Old 04-25-2018, 11:30 AM   #309
Nmbr1GMfan
I feel the window trim will be the most difficult because it needs to slide together and the powder is pretty thick, I think we can make it work though. A few trim parts and the bumpers still need to be done.
Todd Greene
Old 04-25-2018, 11:32 AM   #310
Nmbr1GMfan
Oh cool, I'll try it if I don't just buy a small blast cabinet and get it over with.
Todd Greene
