#301 |
Thank you, I have to find something because my blaster is too big and blows everything into next week.
Todd Greene |
#302 |
Liked 335 Times in 182 Posts
Try a piece you really don't care about with pea gravel that works pretty good sometimes too
#303 | |
Todd Greene |
#304 |
Did some blasting and coating this afternoon. Pedal assembly, some brackets, door handles and trim. Of course I couldn't resist stopping by the shop on the way home to see what it looked like.
Todd Greene |
#305 |
Liked 800 Times in 237 Posts
Will be killer good looking, for sure.
"That'll never work....." |
#306 |
Liked 327 Times in 87 Posts
Door handle looks killer!!!
Thought about blacking out handles, bumpers and window trim on mine... |
#307 |
just thought of another way to remove rust on small parts--antique guys use white Vinegar-Vinegar is really a very weak acid----soak it overnite fully submerged---depending on how bad the stuff is might take a time or 2 to do it---DOES NOT remove paint or other crud just rust then rinse with water and blow dry or put it in the oven or sunlight to heat it up and dry any moisture you might have missed in the blow drying
#308 |
Todd Greene |
#309 |
I feel the window trim will be the most difficult because it needs to slide together and the powder is pretty thick, I think we can make it work though. A few trim parts and the bumpers still need to be done.
Todd Greene |
#310 | |
Todd Greene |
