Old 05-24-2019, 12:20 PM   #1
Eric Voigt
Liked 18 Times in 11 Posts
Default MOPAR BB 727 Trans Shield
Looking to acquire a shield, what works best W/O modifying the floor? CSR?
How much modification is required to the trans to make it fit. I see where the recommend removing the casting tabs and I also found some reference to removing the shifter cable mount which bothers me.
Thanks in advance
Eric
Eric Voigt 7425 STK
Eric Voigt is offline   Reply With Quote
Old 05-24-2019, 01:47 PM   #2
Liked 10,926 Times in 2,257 Posts
Default Re: MOPAR BB 727 Trans Shield
It was a lot of work to get mine fitted in an "E" body.
Old 05-24-2019, 02:56 PM   #3
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
I have one in a '66 B-Body - all I had to do was cut off one of the ears on the bell housing like you mentioned.
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 05-24-2019, 04:43 PM   #4
John Dinkel
Liked 264 Times in 69 Posts
Have you thought about using a blanket? It's easier.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 05-25-2019, 07:58 AM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
On my 67 B body a CSR shield works great without modifying the tunnel . Do not cut the boss near the back of the case if you use a Turbo Action shifter because the cable bracket bolts to it . I do let the back of the engine droop down to allow easier access to the upper bellhousing bolts , have the shield in place while jacking the transmission into position .
Old 05-26-2019, 08:37 PM   #6
Rb105
The csr shield is nice but on my 69 a-body with a big block we had to modify the tunnel slightly
Rb105 is offline   Reply With Quote
Old 05-27-2019, 11:25 AM   #7
340Cuda
Liked 805 Times in 341 Posts
Fit really depends on the car. It ranges from not having to do anything to replacing the tunnel.
Old 05-28-2019, 03:14 PM   #8
Frank Bialas
Frank Bialas's Avatar
Liked 24 Times in 14 Posts
70 B-body DISASTER!!! So I called them, they said the design was for dragsters and if I wanted to fit it in a vehicle with a body that the tunnel will need to be messaged, biggest issue was the hump on the top towards the rear and the strap and mounts. If you have a pro trans you will have to cut it and you will no longer be allowed to re-certify that piece according to the rep
Frank Bialas 1570 STK
Frank Bialas is online now   Reply With Quote
Old 05-28-2019, 04:30 PM   #9
Eric Voigt
I just called and talked with the "tech" line informed them my application was BB 69 B-Body. He informed me that I "might have to roll the body seam line at the floor" some to make it fit. Also, remove the casting tabs at the front as well and what ever I do NOT trim the shield in any manor as they will not "re-certify" the shield as any modification removes them from any liability.
They did state it was designed off a "dragster" application. Why not design around the tightest application first? Oh the joys.....
Eric Voigt 7425 STK
Old 05-28-2019, 06:36 PM   #10
Rod Greene
Liked 242 Times in 81 Posts
Ollie put a stick in it...............lol
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
