Old 08-04-2019, 09:44 PM   #1
Liked 10,921 Times in 2,257 Posts
Default Re: Dumbo The Flying Elephant
8:30 and just finished supper. Left the shop at 8m. The junk CSR puts out and sells made it a very long day. The stuff did not fit within a half a hole. You can't even put the bolts in and have them be 90* to anything. If its modified CSR will not recertify. If CSR would QC check the shield it would not be necessary to modify. News Flash CSR " Almost rite is still WRONG!"
Time to get cleaned up and ready for bed, so I can do it all again tomorrow, starting bright and early
Old 08-06-2019, 06:45 AM   #2
It's amazing how a good night sleep changes a persons outlook on a problem that was so large yesterday. Me using poor judgement almost ruined the threads in the aluminum block where the trans mounts. The fix was remove casting flashing from the trans. Smooth the depressions for the bolts in trans bellhousing. Remove steel bushings and give them .015'' more radial clearance. Slot the shield to move bushing to the centerline of the bolt hole. Enlarging the hole in the shield wont work because the bushing will fall out during installation. The shield floats on the bushings. Straighten the damaged threads in the block. Clean threaded holes, examine bolts for burs and damage threads, repair if necessary, antiseaze, and test fit. Install trans and install bolts with fingers at least four turns in, to verify bolts are not cross threaded. What could be more simple than that?
Does anyone make a locking dip stick that bolts up to a 727 with a shield installed, that does not require modification?
Play time is over back to work!
Old 08-06-2019, 08:32 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,959 Times in 593 Posts
Wow sure sounds like you have had your hands full with this build. Most anything I buy for my car requires some "fitting". I am sure it will be worth the effort when its all done and on the track racing. Best of luck getting it wrapped up for Bowling Green and Indy.
Mike Pearson 2485 SS
Old 08-07-2019, 10:18 AM   #4
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Does anything just bolt up on a race car lol. Thanks for letting us in on the build Larry. Will be cool to see what it does at the track.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 08-06-2019, 08:42 AM   #5
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
I think mine is a Lokar, flexible braided line for the tube. I'll try and send a picture of mine.
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 08-06-2019, 09:59 AM   #6
Thanks
Old 08-06-2019, 04:43 PM   #7
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Dennis Breeden
Larry, mine is a Lokar as well.. One thing is make sure the full line is really full.. I burnt two trannys up before realizing full on the dip stick isn't really full.. I took the tranny pan off and marked the dip stick at the base of the tranny.. Took a file to it.. Now fill to that mark.. all has been well since.. Just what happened to me.. Mack
Mack Reeves
2377 STOCK & SUPER STOCK
Old 08-06-2019, 06:25 PM   #8
Frank Castros
Liked 2,765 Times in 978 Posts
Great advice provided by Mack, but Larry you are into Dumbo very, very deep. I can't wait to see the fruits of your dedication and labor.
Old 08-07-2019, 06:06 AM   #9
From Joel at "Joel's on Joy", who credits Jeff Taylor; always check trans fluid with car in gear with some one holding the brake.
