Old 09-21-2019, 07:50 PM   #1561
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: H-I-J '76 Nova re-fit.
race pack (imo), if you use it all the time its great, but its a pain if you only use it once and a while ,, I have a RPM data logger and it is real easy to use and set up ,
your install is nice and neat,, mine started of that way but added a bunch of stuff ,, it got out of hand
Old 09-21-2019, 09:13 PM   #1562
Frank Castros
Liked 2,727 Times in 961 Posts
Originally Posted by Nmbr1GMfan View Post
Wires wires wires are done. Now I need to figure out how to operate the Racepak.
and, how to react to the data it provides, the new learning curve.
Old 09-21-2019, 09:50 PM   #1563
gmonde
gmonde's Avatar
Ding-Elexa ,tell me what adjustments to make for next round -ding
Old 09-21-2019, 10:13 PM   #1564
FED 387
Liked 333 Times in 180 Posts
They are simply recording data from a run--"you" have to make any adjustments that you feel are necessary--- over time after reviewing the records you have been keeping of each run you will make the "correct" changes to your tune up to correlate a previous run mimic your next run-- you are going to have to enter additional info or keep the info in your log book such as track temp/humidity/grains/density altitude/ etc. to see what your car run in similar conditions---it is not an ET or MPH predictor--- FED 387
Old 09-22-2019, 02:21 AM   #1565
Rod Greene
Liked 242 Times in 81 Posts
Racepak is great if you remember to turn it on so it records the run. At Indy driver forgot to turn it on in 2 runs cost him a class win. At Norwalk remembered to turn it on .2 quicker. He just won class at the Sports Nats.
Moral of the story if you got it use it.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 09-22-2019, 08:34 AM   #1566
J&S Racing
Liked 319 Times in 82 Posts
There is a mode to start the racepak when it hits a set rpm.
Old 09-22-2019, 02:35 PM   #1567
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Start with pg. 22 of the manual for rpm trigger setup. Section 5. That's a nice piece. Maybe start with pg. 1
I'm trying to piece together Innovate Motorsports products for data as a Racepak is out of my budget. You have such nice stuff.
Dale Shearon
68 Mustang 6394
Old 09-22-2019, 08:11 PM   #1568
pfordamx
Liked 7 Times in 5 Posts
our grid will starts to log once it sees the launch rpm limiter activated and above 2500rpm which is nice and it ends up recording every pass we don't have the arc module to record output shaft or driveshaft rpm because of the legality around running it i wish they would make a driveshaft module without the built in traction control stuff for the grid.
pfordamx is offline   Reply With Quote
Old 09-23-2019, 11:23 AM   #1569
Nmbr1GMfan
Originally Posted by gmonde View Post
ding-elexa ,tell me what adjustments to make for next round -ding
hahaha
Todd Greene
Old 09-23-2019, 11:31 AM   #1570
Nmbr1GMfan
I'm sure this would happen. We put the button on the floor just to have it but fully intend to start recording off RPM.
Todd Greene
