Old 09-29-2019, 10:36 AM   #1591
jcw31
Liked 6 Times in 6 Posts
Default Re: H-I-J '76 Nova re-fit.
Well 1st- never said she wasnt doing a good job.2nd - never read where she was backing out of it.3rd GEEZ does that mean somebody peed in your cheerios?
jcw31 is offline   Reply With Quote
Old 09-29-2019, 01:31 PM   #1592
MR DERBY CITY
Liked 7,946 Times in 1,521 Posts
Originally Posted by jcw31 View Post
Is it normal to lose 8 mph between 1/8 and 1/4 ?That just looks wonky.
In all fairness to you, I am still trying to figure out if this is a serious question . perhaps you SHOULD read the entire thread next time.....MJ doesn’t eat Cheerios .....
Old 09-29-2019, 02:10 PM   #1593
Nmbr1GMfan
Originally Posted by Willyracer View Post
I tried to attach a screen shot of setup location of record
Selection Don't know if it sent. If not PM your email and I
Can try to send it that way.
Yes, it appears mine is properly set up and I'm pretty sure it said to wire it to a ground source to activate, which we did. Hmmm!
Todd Greene
Old 09-29-2019, 02:19 PM   #1594
Nmbr1GMfan
Originally Posted by Nmbr1GMfan View Post
(far left timeslip is Indy the rest were last night, we only ran 1/8)
We only ran 1/8 as I stated in an earlier post. Car doesn't pull through the back half well at all but it will gain mph, we're working on that.
Todd Greene
Old 09-29-2019, 02:25 PM   #1595
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Are you using the supplied switch with the kit or your own for activation? There seems to be slightly different wiring if you are using your own switch to trigger record. I'm kind of following along here with a manual, so forgive me if I'm off.
Dale Shearon
68 Mustang 6394
Old 09-29-2019, 02:32 PM   #1596
Nmbr1GMfan
I used the supplied Racepak switch, wired to ground, checked with a simple test light for functionality. I'm sure I missed something and there will be an "Ahh Haaa" moment at some point.
Todd Greene
Old 09-29-2019, 08:33 PM   #1597
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
I might be misunderstaning but how did you test
With the light. The input is taken to ground.
Or did you mean you tested the switch only . I would make
A long jumper and temp short it to the battery neg post
Once removed the racepak led should start flashing (recording)
If it doesn't start recording I would check the 12v and neg wires
Going into the recorder.
The simple things are always the hardest to find.
Lol
Willyracer is online now   Reply With Quote
Old 09-29-2019, 09:19 PM   #1598
Nmbr1GMfan
Lol
I clamped the test light wire to positive and stuck the "record wire", when I push the button the test light lights indicating ground. Also, I'll assume when the ignition is cut after the finish line it will stop recording when I get this sorted out? Now it records till I shut it off in the program.
Todd Greene
Old 09-29-2019, 09:36 PM   #1599
Willyracer
Willyracer's Avatar
I have are wired like this:
The red wire (C position) is connected to the ignition
"on" wire When the ignition is turned off the racepak
Is power down. You can set it up to stop recording when
Rpm drops below a set point for a set time amount
Old 09-30-2019, 11:13 AM   #1600
pfordamx
Liked 7 Times in 5 Posts
off topic a little i'm not familier with racepak but your 1/8th mile et shows low 11 second potential which would put you comfortably under your index if you can figure out why its falling over in high.
pfordamx is offline   Reply With Quote
