#1591 |
Liked 6 Times in 6 Posts
Well 1st- never said she wasnt doing a good job.2nd - never read where she was backing out of it.3rd GEEZ does that mean somebody peed in your cheerios?
#1592 |
Liked 8,052 Times in 1,529 Posts
In all fairness to you, I am still trying to figure out if this is a serious question . perhaps you SHOULD read the entire thread next time.....MJ doesn’t eat Cheerios .....
#1593 |
Yes, it appears mine is properly set up and I'm pretty sure it said to wire it to a ground source to activate, which we did. Hmmm!
Todd Greene |
#1594 | |
Todd Greene Last edited by Nmbr1GMfan; 09-29-2019 at 04:58 PM. |
#1595 | |
Liked 237 Times in 126 Posts
Are you using the supplied switch with the kit or your own for activation? There seems to be slightly different wiring if you are using your own switch to trigger record. I'm kind of following along here with a manual, so forgive me if I'm off.
#1596 |
I used the supplied Racepak switch, wired to ground, checked with a simple test light for functionality. I'm sure I missed something and there will be an "Ahh Haaa" moment at some point.
Todd Greene |
#1597 |
Liked 57 Times in 24 Posts
I might be misunderstaning but how did you test
With the light. The input is taken to ground. Or did you mean you tested the switch only . I would make A long jumper and temp short it to the battery neg post Once removed the racepak led should start flashing (recording) If it doesn't start recording I would check the 12v and neg wires Going into the recorder. The simple things are always the hardest to find. Lol |
#1598 | |
Todd Greene |
#1599 |
I have are wired like this:
The red wire (C position) is connected to the ignition "on" wire When the ignition is turned off the racepak Is power down. You can set it up to stop recording when Rpm drops below a set point for a set time amount |
#1600 |
Liked 7 Times in 5 Posts
off topic a little i'm not familier with racepak but your 1/8th mile et shows low 11 second potential which would put you comfortably under your index if you can figure out why its falling over in high.
