Old 03-01-2022, 01:46 PM   #541
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: Dumbo The Flying Elephant
Got my new CB663 XXX bearings today but my new micrometer won’t be here until Wednesday. Odds should be in my favor that I get some good bearings.
Larry try the King CR807XPN bearings. Very consistent thickness. Better than clevite's.
Old 03-01-2022, 06:57 PM   #542
pmrphil
Liked 348 Times in 152 Posts
And I'll add that I see less "delamination" with the King over the Clevite when they've been pounded.
Phil Molski
PMR Performance
S/C 1623
Old 03-02-2022, 09:41 AM   #543
Liked 10,767 Times in 2,238 Posts
I think I have King's in the pink car. What ever is in there its goin on its third season.
Old 03-03-2022, 02:24 PM   #544
I received a new set of CB663xxx and they are good enough to install in a rod and check for clearance. Each shell got checked six places along the part lines for thickness variance and recorded in the Dumbo book
Old 03-03-2022, 07:24 PM   #545
pmrphil
What did you see for differences?
Phil Molski
PMR Performance
S/C 1623
Old 03-04-2022, 08:54 AM   #546
Out of the 96 places checked .0588” to .0595”, so thick to thin was .0007 and no shell had a variation of more than .0004.
Now they will be installed in the rods and checked for vertical clearance and taper. If all of that is ok Dumbo will have a fresh set of bearings.
Hats off to the real engine builders that have to fight this kind of stuff on a daily basis.
Old 03-04-2022, 09:47 AM   #547
pmrphil
Did you also order a set of King's? You may be surprised at the difference. I won't say that they are the cat's meow, but I like what I see when stuff comes in for freshen ups. The Clevite's are probably good enough for 85% (or more) of the engines out there, but I usually see better consistency with King, and sometimes ACL, depending on application.
Phil Molski
PMR Performance
S/C 1623
Old 03-05-2022, 11:51 AM   #548
I have two CB 663's and one set of ACL so I should be able to get something to work. If not I will get a set of Kings
Old 03-05-2022, 12:02 PM   #549
Got the pink car running yesterday after it being rewired and with all new Classic Instruments gages. I think we solved the occasional no start problem, a bad fuse block. For some reason I had another one on the shelf.
Old 03-05-2022, 11:17 PM   #550
Glenn Briglio
100 percent correct on King bearings
