Old 10-18-2023, 12:20 PM   #25
Ellis V Buth
Liked 420 Times in 73 Posts
Default Re: National Record Postings
The minimum that is posted is already .5 under the index. You would only have to exceed that to set a record.
Mark is right. It is .5 under the index to set a record. W/SA, for example, has an index of 16.65. The minimum is 16.15. So if I wanted to set a record, I'd need to make 1 run of 16.149 or quicker and then another run within the range to count as a backup in order to reset the record from minimum.
Ellis V Buth is offline   Reply With Quote
