Old 08-10-2025, 01:04 AM   #1181
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Default Re: Dumbo The Flying Elephant
Part of the problem is me and my size.
Good thing you don’t have a late 60’s Mustang with an FE. LOL
Mike 7570 A/SA
Old 08-11-2025, 10:40 AM   #1182
Liked 10,837 Times in 2,252 Posts
Had a neighbor that had a 69 car with 428 and one really long Saturday we installing them in the parking lot of the apartment. The bottom bolts were a real challenge. Worst thing eight pipes and no instructions. It did not go smoothly.
Old 08-14-2025, 11:36 AM   #1183
Things are starting to look better.
Old 08-14-2025, 12:05 PM   #1184
Mike Gray
Mike Gray's Avatar
Note to self: Never buy an FS/ anything!
I’m lost just looking at the wiring and hoses.
Mike 7570 A/SA
Old 08-14-2025, 07:29 PM   #1185
Configuring the car will take a little time. Every channel has to be assigned with parameters. Holley videos are a big help. I think they are very good for us non computer folks it has easy step by step information and playing along builds my confidence
Old 08-15-2025, 05:54 PM   #1186
goinbroke2
Liked 404 Times in 158 Posts
You have more patience than me Larry!! I just pulled the CFI off my 93,000km all original 86 mustang. Pulled that and stuck a 2bbl on. If the timing doesn't stop acting up it'll get a duraspark distributor too! Not into diddling with EFI I guess, looking at simplicity.
I certainly see where it can be beneficial in a higher hp combo though where each cyl can be fueled and timed separately by computer.
Keep it up, loving the thread!
Jim Miller
103 U/SA
Old 08-17-2025, 03:15 PM   #1187
The hood is on and we think all wires out of danger. Out to the trailer to get nitrogen bottle to fill shocks. Nothing work in trailer changed battery to group 31 AGM. Had to move position of battery 90 degrees and bolt it to the floor. All wires were long enough to connect I just had to reroute them to get the covers to fit. Rivnuts to the rescue. Need to order bulbs for flood lights. Fill engine with water and scale.
Old 08-18-2025, 01:43 AM   #1188
Cglrcng
Cglrcng's Avatar
Liked 396 Times in 208 Posts
My hands and lower arms looks like I have been fighting with cats and losing. Hope to be at BG next week to race and test.
With every zip tie you use cut close, then always use a bic lighter on the cut tail to slightly melt and dull the end. Works on FIRST High School robots and autos.
Thank me later. It is fast and efficient.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 08-18-2025, 02:40 PM   #1189
Steve Grady
Steve Grady's Avatar
Liked 132 Times in 44 Posts
Hope we get to see you make some runs this weekend at Beech Bend.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 08-18-2025, 07:48 PM   #1190
Bad news. For some reason I have misplaced my AW-32 adapter for the regulator for the nitrogen cylinder. Shocks get around 125 psi of nitrogen to make them work. I order two of them and should be here next week. We are going to miss D3 Pts race at BG. No way we can be ready by Thursday test and tune.
And so it goes
