I assume coast RPM is RPM on the stop. I would try for 4100 to 4500 RPM.The convertor will flash to stall speed when you come off the stop. Shifting by time & being in high gear when you come off the stop will help alot with wheel spin . The higher the RPM on the stop, the longer you will have to be on the stop to slow your car down.
