Liked 93 Times in 52 Posts
Does the car idle well in gear?
Are the throttle blades manually adjusted to be open too far and uncovered the transfer slot? Last edited by cad; 08-28-2009 at 09:22 AM. |
Last item I have is an article that talks about baseline setup, and the transfer slot:
http://www.carcraft.com/howto/77958/index.html |
Well guys, changing the squirters was night and day difference, car launches way better with no stutter at all.
I tried it today the way it has always been set up and it went a 13.20 - 1.870 60 ft. and with just the .037 squirter change it went a 13.08 with a 1.840 60 ft. So im very happy with how it is launching now Thanks for all the help ! |
Liked 92 Times in 29 Posts
Clark, spring would definetely affect the launch. A bog from a too light spring can also cause consistency issues.
C, glad to hear you fixed it. If you have time this weekend or another weekend humor yourself and try that spring. It should help. Good luck. |
#5 | |
Thanks Jody, At the next test and tune I will try a heavier spring for sure. Thanks, Craig - C693 |
Jody, using the .37 squirter and your choice of 72/76 jets works like a charm on this carb and my set up !
but now at idle i am getting a "pop" every once in a while, does not seem to be affecting the performance or anything, just wondering what this could be ? Thanks, Craig Last edited by CJohnson; 09-22-2009 at 06:03 PM. |
one of your posts said you were going to put in a 7.5 power valve in place of the 6.5. you should be going to a lower #.
Check your vacuum at idle. Being a drag car you can use anything under the vacuum it idles at. 3.5 might be a good choice. It sounds like a lean pop but it could be the power valve leaking too much fuel into the engine??? Have you tried a different spring yet? |
