Originally Posted by Paul Ceasrine
Alan,
if you check out the "Mods for Mopar 273" article, Feb 66' Hot Rod,
with Tom Hoover and Mike Buckle (of the Ramchargers), you can see the first free-breathing intake manifold. A standard 273 cast iron intake, with the carburetor butterfly openings cut-out to 1 11/16" (primary and secondary) for the first Holley carb to be mounted on the intake, during
the early stages of the D-Dart. The first carb used was a 4160 #3116
600 cfm, off the 65' Race Hemi's.
Paul
Paul,
Hot Rod (I think) also did an article about using the carb base from a 3705sa carb from a '64 Max Wedge and putting it on the 273 4bbl manifold then put the rest of the stock carb on this base so that unless you looked real close you would swear it was stock.
JimR
