Old 02-17-2010, 07:40 PM   #1
Z28Racer93LT1
Default Re: Best way to slow a car down ?
Weight, shift lower, take timing out. That will get you there.
Z28Racer93LT1 is offline   Reply With Quote
Old 02-17-2010, 07:50 PM   #2
Mongo
I prefer lifting and or using the brakes.
Mongo is offline   Reply With Quote
Old 02-18-2010, 04:42 PM   #3
CJohnson
CJohnson's Avatar
Dumping a full 9 tenths ... no thanks
CJohnson is offline   Reply With Quote
Old 02-18-2010, 05:27 PM   #4
d1hitter
Banned
put a FORD motor in it.
d1hitter is offline   Reply With Quote
Old 02-18-2010, 06:12 PM   #5
CJohnson
CJohnson's Avatar
Ya, that should do the trick.
Old 02-19-2010, 12:01 PM   #6
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
He said he wanted to slow down a second not make it a second faster....lol..
Mechanical throtle stops work good, would need to add too much weight to get that much out of it...
May try swaping out the 4bbl for a decent 2 bbl carb... less fuel/air= less power....
Freddie is offline   Reply With Quote
Old 02-19-2010, 07:19 PM   #7
CJohnson
CJohnson's Avatar
Thanks for the suggestions guys, I picked up a throttle stop made by moroso today. looks like it will work pretty good !
http://www.jegs.com/i/Moroso/710/650...oductId=764313
Old 02-24-2010, 05:34 PM   #8
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Talking Re: Best way to slow a car down ?
Have DJ Raiser drive it! Hell my car never left the water box!
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 02-27-2010, 02:09 AM   #9
fast69sschevelle
This is the cheapest way to do it, and much easier to adjust than a bolt under the gas pedal. I know an old super street 10.90 racer that still uses this part to slow the car down for that index. Best of luck.
fast69sschevelle is offline   Reply With Quote
