Old 03-17-2010, 02:31 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Re: fuel pump of choice"?
I had a similar issue and talked to Product Eng about my fuel pressure setting for gas and the routing of the lines from regulator to the carb. I was running an adjustable fuel log at the time. Product Eng mentioned to bump up to 8.5 lbs and to keep the regulator in front of the motor with separate lines run from the regulator to the carb bowls. I haven't had your same problem since and he (can't remember his name) has seen many issues with fuel line routing and fuel logs causing regulator output issues. Hope this helps some
N/A
mannymen is offline   Reply With Quote
Old 03-17-2010, 08:06 PM   #2
d1hitter
Banned
cracked rotor.
d1hitter is offline   Reply With Quote
Old 05-09-2010, 12:29 AM   #3
rayfin
Had the same problem. Ditched my mechanical fuel pump and used an electric only. I think todays gas sucks.
rayfin is offline   Reply With Quote
Old 05-09-2010, 08:12 AM   #4
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
cracked distributor cap.check it good.
astikhossw is offline   Reply With Quote
Old 08-03-2010, 11:07 PM   #5
rayfin
Did you ever figure it out ?
