Old 06-15-2010, 07:15 PM   #11
ron mattson
Liked 68 Times in 31 Posts
Default Re: How much converter slip??
The formula above is for radial tires, bias ply tires will grow, each manufacturer can
tell you approx how much at a given speed for any size tire. Like Alan stated each
car can vary in how much flash it will take to get it moving and how it will lock up on
the big end will depend on how much power and powerband width are available.
Most of the converter companies can get you really close if you give them accurate
info for hp, tq, weight,gearing and rpm potential. one other variable is where you race
sea level will differ greatly from altitude and so on. trial and error!!!! just my .02$
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 07-18-2010, 05:59 PM   #12
demps45
I could be wrong, but if you record the engine RPM, and record the driveshaft RPM, assuming your in high gear and it's a 1:1 ratio, then the difference would be the converter slippage.
Fred Dempsey
G/S, H/S, I/S, D/SA
demps45 is offline   Reply With Quote
Old 07-18-2010, 06:34 PM   #13
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
In my SS car, according to the Racepak, 5% on a good run, 6% in poor air. Dyno
Old 07-19-2010, 04:52 PM   #14
Don Turk
Liked 51 Times in 12 Posts
Dyno
My race Pak is showing similar like 1 or 2% Just curious how you calculate the percentage of slip.
Just curious for comparision sake
Thanks
Don
Don Turk is offline   Reply With Quote
Old 07-19-2010, 06:27 PM   #15
Jeff Stout
Liked 706 Times in 283 Posts
Using my ultimate 2 tach I came in at 3.5%.454 390 HP SS car
Old 07-20-2010, 12:55 PM   #16
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: How much converter slip??
Originally Posted by Glenn Briglio View Post
Most flogged out combos will have less than 5% slippage. Works on our car!
Glenn, who makes these converters that you mentioned? You can pm me if you want to. Thanks
Robert
Robert Simpson is offline   Reply With Quote
Old 07-20-2010, 12:59 PM   #17
Robert Simpson
Originally Posted by ron mattson View Post
Robert, to figure slip multiply your mph say 114 x gear ratio 5.13 x 336= 196499 then
divide by tire height 29.5 = gives you a rpm of 6661 then multiply by 1.08 for 8 % =7193.
just enter your correct values. mph x gear ratio x 336=@ then divide @ by tire height =true rpm with no slip and multiply by 1.08 for 8% 1.09 for 9% and so on to get your final rpm .
Ron thanks for the info. At times it is hard to see 7000 or 7050, but I have gotten close. Ron, who do you recomend?
Robert
Old 07-20-2010, 06:47 PM   #18
Dyno
Dyno's Avatar
Don, it will show in the Engine/DS ratio on your Racepak data. Check it at the end of the run.
Old 07-20-2010, 09:07 PM   #19
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Smile Re: How much converter slip??
No secret Mike Munsinger is the man for torque convertors.
Old 07-21-2010, 05:42 AM   #20
Don Turk
Thanks Dyno
When I was looking at the Engine/DS ratio it is 1.073 I had assumed that was 7.3% slippage. However when I did the math Engine RPM 6134 D/S RPM 5715 I came up with 6.9%. Not trying to split hairs here just trying to understand the math.
Thanks Again
Don Turk
