Old 01-24-2011, 04:45 PM   #1
bottombulb
Default Re: QA-1 coil over conversion kit
The QA-1 coil over kit is an excellent product. Just make sure you get the correct spring. I can help you figure it out if you're interested.
bottombulb is offline   Reply With Quote
Old 01-25-2011, 11:30 PM   #2
380 Olds
The QA-1s work very well. Very easy to adjust and the adjustments do what they are supposed to. I also agree you need to get the right spring.
380 Olds is offline   Reply With Quote
Old 01-26-2011, 09:56 AM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
must be an oldsmobile thing
Speak to stock/super stock chassis builders and those with a shock dyno and they'll tell you they are junk compared to Afco, Santhuff and Koni
Old 01-26-2011, 02:11 PM   #4
bottombulb
They will also tell me there is no need to deep stage either.
That being said, if I ever get to the point where my QA-1's can't control my wheelstand anymore, then I'll install the Afco BNC's.
Old 01-26-2011, 03:33 PM   #5
1320racer
1320racer's Avatar
They might but I won't and when/if your ride wheelstands like mine, you'll be making the swap to DA BNC Afco's.
Old 01-26-2011, 07:57 PM   #6
380 Olds
It does and I won't.
