Old 03-04-2011, 06:45 PM   #1
Joe Hertline
Liked 3 Times in 2 Posts
Default Re: what to use to clean trailer
Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
Scotchbrite works well on the aluminum floor...all you need is a case of that, a sanding block, and a free weekend. After that initial scrub, there are aluminum waxes that make it easier to restore the shine - make sure you wipe up any water or fluid that might hit the floor and it'll last for a while.
Joe Hertline 1318 SS/FA
Joe Hertline is offline   Reply With Quote
Old 03-04-2011, 07:51 PM   #2
FED 387
Liked 336 Times in 183 Posts
Ditto on Simple Green do it in the shade and start at the top and work your way down---Get it at Wal mart for about $8 a gallon--its cheap and effective & it works well
Old 03-04-2011, 07:59 PM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: what to use to clean trailer
Wayne..... You have a PM.
Dave Ribeiro 1033 STK
Old 03-04-2011, 09:11 PM   #4
dbochan
Send a message via AIM to dbochan Send a message via Yahoo to dbochan
Use RV455 to remove tough black streaks and grime. I was sceptical until i used it and It removed black streaks from a trailer that was sitting and not washed for 6 years by just spraying on and wiping off. It strips off the black streaks as well as any wax, so you must wax it right after cleaning.
dbochan is offline   Reply With Quote
Old 03-05-2011, 01:55 AM   #5
Damn Yankee
Several guy's over on yellowbullet.com swear by LA's Totally Awesome cleaner. Best part is it is sold at Dollar General and is fairly cheap.
Damn Yankee is offline   Reply With Quote
Old 03-05-2011, 11:56 AM   #6
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I use this product, and it works very well on "streaks". Be aware.... It is pretty aggressive. Don't use it in the sun (surface should be relatively cool), and rinse with clear water before it dries......
Old 03-05-2011, 12:46 PM   #7
Damn Yankee
Is it a soloution that could possibly be deluted and mixed in with water in a bucket ?
Old 03-05-2011, 10:14 PM   #8
68camaroSS
[QUOTE=Joe Hertline;243895]Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
X2 on that for black streak removers. They will take off the black streaks, but wait to you see what it does to your shiny aluminum trim, it spots and tarnishes them, and I followed the directions. Learned my lesson the hard way.
68camaroSS is offline   Reply With Quote
Old 03-06-2011, 12:15 AM   #9
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Along the same line what wax are you guy's using after it is clean? Thanks, Brian
b.guggenmos is online now   Reply With Quote
Old 05-17-2011, 08:55 PM   #10
AdemE
I have freind that owns a detail shop that races with us in superstock up in the northwest that has a special mix for trailers and RV u can call troy at NW Quality detail (253)351-0809 he sell supplys to
AdemE is offline   Reply With Quote
