Old 09-01-2011, 09:19 PM   #2
magnumv8
Default Re: Line lock with ABS brakes ????
Jerry....line-locks are front wheel only by the rulebook....as far as interfering with the rear antilock system that shouldn't be an issue (I ran a truck for a long time with the same setup)....sometimes I would get a "brake indicator" light on the dash but it was a non issue....as far as holding the truck on the starting line, I have seen a couple one legged drivers, one used a hand brake and the other used the "road racing" trick of heel and toe that does take some practice to master...only holding 800 to 1000 rpm it shouldn't take a lot of brake pressure to hold your truck on the line even with a stock convertor......
D L Rambo.....
magnumv8 is offline   Reply With Quote
