#11 |
Liked 9 Times in 2 Posts
The only downside to runnig a cage is that it has to be certified every 3 years. A roll cage that is not NHRA certified is only good to 11.50 et, a roll bar with a un-modified floor pan is good to 10.00 et. I would still put a roll cage in. $0.02
Larry |
#12 |
My understanding is that the Cage only has to be certified if the car
is fast enough to REQUIRE it to have a cage. My car has had Cage and been race continually for 18 years and show No Flex of Body unlike a lot of my other cars. I believe that it further makes the car stiffer and easier to tune chassis. We did remove Windshield to Fab it and get everything to fit as close as possible. |
#13 |
Are you sure about that? Makes no sense................
2009 V/SA Record Holder |
#14 | |
Liked 2 Times in 2 Posts
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#15 | |
Liked 6 Times in 4 Posts
I run a cage, no cert. @ 10.31 et.... |
#16 |
#17 |
There is a track in WI that states that this is a rule, but I just looked it up and the rule specifically states that you only need a cert if you are running 7.50-9.99. Sorry for the misleading information.
#18 |
Liked 6 Times in 3 Posts
also, contradictory to what was posted below and another post a couple months ago on this board, that overly bashed a chassis builder for not fully welding the cage on the halo attachment points. the cage does not have to be fully welded. as long as the cage is properly fit and welded properly 3/4's around the tube and corner gussets are added then it will pass tech with flying colors! gussets can be in the form of small corner plates or small diameter round tube. this is how chassis builders are able to tuck the cages up to the headliner real tight on cars without cutting holes in the floor! those silly little gusset plate or small diameter roll bar tubing welded in the corners aren't just there for looks.
don't let the flashy paint fool you! Ian |
#19 |
Interesting...
#20 |
Liked 154 Times in 37 Posts
Do you have to run a window net in a stocker that is not required to have a cage but does?
66W30POST |
