Old 10-11-2011, 12:19 PM   #8
jmcarter
jmcarter's Avatar
Liked 3,235 Times in 984 Posts
Default Re: Throttle Stopping
Originally Posted by CUBEMAN View Post
I will go to idle at .2 or .3 and shift @ .6 and thought that with a car that can run at least 1.75 under index that I would start by taking that amount (1.75) and stay on the stop that amount of time for starters. By running a Terminator I will go to idle quickly. I could be all wet here
You're assuming a 1 to 1 ratio and that's incorrect...remember you're still covering ground while on the stop. And your RPM on the stop needs to be up in the ~4200 range. Think the others are right with 2.50 being close. Danny and his son can get you close too...better do the test and tune, you'll need 2-3 laps to even get close to your ratio.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
