Old 10-11-2011, 01:19 PM   #1
jmcarter
jmcarter's Avatar
Liked 3,244 Times in 986 Posts
Default Re: Throttle Stopping
One of Biondo's excellent primers on stops, more on their site. They are great to deal with and one of ClassRacer's sponsors BTW.
http://www.biondoracing.com/manuals/...20Stops/TS.pdf
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-11-2011, 03:15 PM   #2
Duane Dagostino
Going to idle w/fi changes a lot from carbs...try to find a racer with the same set-up,you could wind up 1-1 or close
Duane Dagostino 1821 S/C, S/G
Duane Dagostino is offline   Reply With Quote
Old 10-11-2011, 04:01 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
You can install an electric leanout......turn it on when you go on the stop.
Experiment with pills to see what runs clean at somewhere around 4000 and once you have that done you can run your injection just like a carb.
Thats what I did and it worked well for me . I used a .050 pill in my leanout if I recall right.
Most people go to an idle with injection and if that works for you fine.....
I killed a second to go 8.90....and had close to 2 seconds stop time usually and used the leanout all the time.
One race the car was not responding to t-stop changes right.....I went down to 4 cars anyway..
I discovered the coil for the electric leanout had burned out and the leanout was not opening and that was why my t-stop time inputs were not following as they should have..
I have a Terminator on my dragster now.....never installed the leanout yet...mostly bracket race with it...
Rich Biebel
S/C 1479
Stock 147R
Old 10-11-2011, 10:24 PM   #4
CUBEMAN
I have a electric lean-out on it with a .40 in it. Just like to throw something in the ole pit and see how we all look at it. More than likely will test and throw 1.75 in for a starter and then a change to get the multiplier and give them a whirl.
CUBEMAN is offline   Reply With Quote
