Liked 282 Times in 78 Posts
Dennis and Rich,
There is not a divider or ducting, so chances are it is recirculating the same heated air, and just heat soaking everything. It looks like when the trailer was built they just windowed a hole under the generator in the plywood. I found info on the web about the ducting kit that was being installed. So definitely a trip under the trailer is in order to rule out what you guys have pointed out here. I really appreciate the advice and help. Sean
