Old 07-03-2007, 11:11 PM   #1
Mike Hedger
Default Re: Dedenbear T Stop Timer
Have you made a blade angle change to the t stop and tried to get away from the 3.0 range to see if it is predictable? I would try two more turns under the carb (12 rounds to 14 for ex) and see if you can get to 2.5 sec and see if it still does it. It sounds like the .9 # is the faulty digit/timer. You will love the 450 and all it has to offer. one box does everything and then some. Hope this helps, Mike
Mike Hedger is offline   Reply With Quote
Old 07-04-2007, 02:15 PM   #2
Dustin Chase
Dustin Chase's Avatar
We have not run the car wide open with this motor. We run the throttle stop at 15 turns in I believe. We are killing it a bunch and its a big car. We also don't kill it until .50 into the run. Like I said this is a big car and we want to get a good launch and 60 foot.
Dustin Chase Comp 470 K/A
Dustin Chase is offline   Reply With Quote
Old 07-04-2007, 03:01 PM   #3
Mike Hedger
When I had my S/St car I killed it at .002 to try to kill the wheelstands, and it got the 60' to repeat quite a bit better, Remember the sooner you kill it and get it back wide open the more MPH you will run. (My chevy 2 ran 10.90 at 144) you will also have less time in the timer witch will make the car more predictable. Try it you might like it. Mike
Old 07-05-2007, 07:56 PM   #4
Dustin Chase
This is a 3300 lb car but i think we will start at .010 in the stop and see what happens. Thanks for your replys guys
Old 07-07-2007, 09:49 PM   #5
sc1153
sc1153's Avatar
Send a message via AIM to sc1153
Dustin
do you know what the RPM on the stop is? Do you shift on time or RPM.I have found that between 3900 and 4200 rpm's on the stop is optimal. If you have too high of stop rpm the car can accelerate while on the stop and get close to the shift point RPM if the car jumps off the stop and goes directly into high gear you will LOSE a bunch of ET. Sometimes the car will even shift while on the stop. (even worse). If the stop rpm is too low the boosters in the carburator will float and dump fuel (not good)
If you dont know how to check the Stop stall here is what you do.
1) pull the launch chip from the 2step
2) engage the stop (pull the lines off the air feed) so the stop blades are closed
3) start the car and put it in first gear
4) press the trans brake button
5) mat the gas and watch the tach (for about 1-2 sec)
that is your stop stall within 100-200 rpm
Check it out & let us know
Chris DePascale
S/ST 1531 & S/C 1153....Addicted Racing
Jad153@aol.com
sc1153 is offline   Reply With Quote
