Old 01-02-2013, 02:10 PM   #1
Hemi Moose
Liked 12 Times in 12 Posts
Default Re: 1968 Mercury Cougar GT-E 427/390 HP
Old 01-02-2013, 03:26 PM   #2
Paul Ceasrine
Liked 10 Times in 10 Posts
Some general specifications,,,,
* Car Weight #3616 lbs.
* 123 lbs. of added 'Sound Deadener'
* The 427 engine weighed in at a heavy 675 lbs.
* Expensive to build
* Regular 390 GT Exhaust manifolds
* Single-point distributor
* Simulated hood scoops
* Nose-heavy car (Bumper, Hide-Away Light Assembly, Die-Cast Hood)
* Camshaft (Hydraulic) .481/.490 lift - 270*/290* Duration - 46* Overlap
* Rating = 390 HP @ 5600 RPM
* Torque = 460 Foot/Pounds @ 3200 RPM
Performance complaint. The car wouldn't rev near the numbers the factory stated. The valves started to float at 4600 RPM's.
Recommendation (For Street Applications)
* 3.91 Traction-lock gears (at a minimum)
* TRW .515 Lift - 300* Duration (Hydraulic Camshaft)
* Higher-rate valve springs
* Adjustable rocker arms
Old 01-02-2013, 11:33 PM   #3
gt350hr
Not to mention the 600cfm Holley. The CJ GTE's ran circles around them in a lower class!
gt350hr is offline   Reply With Quote
Old 01-03-2013, 10:15 AM   #4
Paul Ceasrine
Ford #C8AF-AD.......Model #4150.....List #4088.....600 CFM
Specific for the 1968 Cougar GT-E 427/390 HP (Automatic Transmission)
Old 01-04-2013, 10:24 AM   #5
Paul Ceasrine
From the factory,,,,,,
Ran 15.10 @ 93 MPH
But, 'GT Performance' out of Frankfort, Kentucky ran one in C/SA in 1968, and was able to get their car into the 12.70's @ 111 MPH.
I'll see if I can find what they did to the car.
Old 01-05-2013, 01:32 PM   #6
Jack Parris
Liked 4 Times in 1 Post
Here are some pics of one I saw at a car show in Vancouver, WA back in 2009.
Name:	Vancouver RT club show 029.JPG
ID:	15038   Click image for larger version
Name:	Vancouver RT club show 030.JPG
ID:	15036   Click image for larger version
Name:	Vancouver RT club show 028.JPG
Jack Parris is offline   Reply With Quote
Old 01-05-2013, 02:47 PM   #7
Paul Ceasrine
The 1968 427/390 HP really got 'trashed' by the critics, as 'too expensive' and a 'non-performer'.
