Old 11-13-2013, 10:24 PM   #1
RonTheAnnouncer
RonTheAnnouncer's Avatar
Default Re: Hi all! New Guy here, Low Buck Comp build, E/ED
Originally Posted by Marty Knox View Post
This is an idea I got from Tom Langdon. Pair the 1 and 6, 2 and 5, and 3 and 4. The idea is to increase the mid-range torque.
Way too much thought put into that. Just run zoomies!
Good luck on your build, Micro, I applaud your courage trying to run comp on a budget! I love looking at all of the wild engine combos guys run in that class.
Ron Huntley, Jr.
announcer and Half ed racer
"Those who can, do. Those who can't, criticize."
RonTheAnnouncer is offline   Reply With Quote
Old 12-07-2013, 06:50 PM   #2
MICROMACHINE72
Couple of new pics from last couple weeks up to today.. Need to get my ***** in gear if we are so make our goal to the gators.. Cutting the tops of the sleeves on the Bridgeport, Made a little fixture and final decked it today! Hurray! Might go out in the garage tonight and set up the final bore operation 4.00. Picked up this little Jewel (crank grinder) this past Thursday at an auction. I think I'm the only one in the neighborhood with one! 5.4 "stock" Triton-mod-motor rods ready to go!
ID:	22305   Click image for larger version
ID:	22306   Click image for larger version
MICROMACHINE72 is offline   Reply With Quote
Old 12-07-2013, 06:53 PM   #3
MICROMACHINE72
rods..
Old 12-13-2013, 06:18 PM   #4
MICROMACHINE72
Cam showed up today.. $225! This was the most expensive part so far.. I thought he was going to cut me a break to run his decal, but that didn't happen Oh well. Solid flat-tappet, .610 lift, 270 @ .050, 106 lc. My projected budget was around $1500/$1700 on the motor ready to run, I'm already up to $1500, so looks like its going to be more like a $2500 build when all said and done. Need to finish the crank work, gas port the pistons, and we are ready to start assembling the short block. I'll post up some more pics when I have some better progress photos to show. -Mark
Old 12-23-2013, 07:50 PM   #5
MICROMACHINE72
Well the holidays are here and progress has slowed down some. Was out in the garage last night for a couple hours trying to lighten up these lead slugs a little more. down to 600g. flat. still real heavy by today's stds., but it is what it is. I think I can get another 15-20g's out of the pin though! Block is sitting in my manual labor hone, LOL. waiting for me to finish the home-made tq. plate up. Torched it out today, as you can see the rough shape, a couple more evenings on the mill and I'll have all the head bolt holes in and surface it. Made it out of 1-1/2 thick A-36. Maybe get block finally finish honed by the weekend if I can complete the torque plate between all the family Christmas festivities. Merry Christmas to all board members!!
ID:	22509   Click image for larger version
Old 12-23-2013, 09:35 PM   #6
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
I all for you, so good to see someone doing it the way it used to be done.
Have you ported your cylinder head yet?
Old 01-07-2014, 08:11 PM   #7
MICROMACHINE72
Thanks! I just started on the cylinder Head, I actually have 3-cores. I will do one the best I can myself, then when I get a few extra bucks this spring I'm going to send another out to Sissel or Valley Cyl. head for a pro-port job and compare results. Finally finished the TQ plate, got the carb adapters on the intake. Going tomorrow to use a buddy's flow bench for some pre-lim data. Also picked up 2-donated holley 500 cfm 2-bbls. Going to try them on the dyno first, along with 2-450 mech. sec. 4-bbls- than finally the 2-660 center squirts. Project moving a little slow at the moment, but nevertheless is moving..
ID:	22595   Click image for larger version
