Old 12-17-2013, 03:18 PM   #21
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: 1965 Impala BBC Stocker Update
Are we allowed to use a 4 Speed (4L60) auto if we use only the 1-2-3 Gears?
D
Old 12-17-2013, 07:09 PM   #22
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Originally Posted by impstocker View Post
Here are new pics of the finished frame. Most important section to strengthen is the rear upper control arm crossmember. They tend to pull out.
Wil,
Being a newby I would say that I am surprised you are allowed to triangulate the stock suspension mounts with DOM tubing. Then again the rule book doesn't say you can't. If and when we put the 396 in our 69 Chevelle to go C/S racing I am going to do the same. Have you talked to your Division Tech about where the triangulation 'stops' being legal? Good looking build.
Andy Friar
Andy Friar is online now   Reply With Quote
Old 12-17-2013, 08:55 PM   #23
MICROMACHINE72
VERY NICE! I love big cars with 4-speeds! The way it was! What motor combo will be run? I'm not too familiar with stock elim. stuff, I guess its a 396-350hp oval port base? I think I have a good steel crank if needed. -Mark
MICROMACHINE72 is offline   Reply With Quote
Old 12-18-2013, 01:31 PM   #24
Harry 6674
Originally Posted by Andy View Post
Wil,
The tubing is permanent ballast? Could be.
Harry 6674 is offline   Reply With Quote
Old 02-08-2014, 01:25 AM   #25
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Here is the completed rear- 4:88's Moser 33 pline spool with rifle drilled axles, "star" flanges, also rear upper control arms, $30 each to builld in parts, not a "dime rocket" but the last time i had someone else fabricate them for my 68 they were $400- don't have that $ now! Also my "poor boy" solid front upper control arm brass bushings. Chucked up on a lathe years ago machined to fit my control arms. Donated brass- total cost $0 Car is wrapped up outside from snow, frame is attached now.
Will Lamprecht 65 Impala 396/325 I/SA in progress
ID:	22879   Click image for larger version
ID:	22880   Click image for larger version
Old 02-08-2014, 03:40 AM   #26
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
D
That's the way I read it. (Copy/paste from rule book)
TRANSMISSION, Automatic
Any model transmission, same make as car, with a maximum of
three forward speeds (unless OEM equipped with more than
three forward speeds). O.D. gear not required, reverse permitted.
Rich Taylor
I/SA - 321
Old 02-08-2014, 08:16 AM   #27
Billy Nees
Looking good Will, I can't wait to see it at the track!
Billy Nees 1188 STK, SS
Old 02-08-2014, 10:08 AM   #28
Alan Nyhus
Liked 799 Times in 236 Posts
Nice work! -Al
"That'll never work....."
Alan Nyhus is online now   Reply With Quote
Old 02-08-2014, 10:18 AM   #29
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
looks great. weather stinks here in ny. pics are good these days, lol.
chris ok is offline   Reply With Quote
Old 02-13-2014, 01:52 PM   #30
66 BELAIR
Is that a brace in that location? If so, how dose the panhard bar attach,and work? I had to modify one just to clear that type of cover.Thanks.
66 BELAIR is offline   Reply With Quote
