Old 03-03-2014, 10:46 PM   #1
philbilly
philbilly's Avatar
Default Re: Dyno numbers 305
Pistons arrived today from cp. I ran rotating assembly over to Terry Smith and got the final balance. We got about all the rings ready. Block is prepped and ready. Looks like I might make South Georgia.
If I have enough time I am going to run it on the dyno. I may have to settle with a few laps up the road! I will dyno when I get in from the gators.
philbilly is offline   Reply With Quote
Old 03-03-2014, 11:51 PM   #2
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Good luck Phil ! I wish I could be there @ sgmp too !
2894 STK
Old 03-04-2014, 12:05 AM   #3
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Yeaaaa for Pistons! Go-Go-Go!
Old 03-07-2014, 11:17 PM   #4
philbilly
philbilly's Avatar
Naives engines finished my engine around 7. It was around 3 am finishing up everything in the car. It was a little late but my neighbors understand. No dyno time so I had to run it a bit. Everything seemed good so we loaded it on the trailer an headed to South Georgia . No runs today but tomorrow will be the tale of the tape. I got my fingers crossed. I will post up some numbers good or bad.
I have no idea what to launch or shift at.
Old 03-07-2014, 11:22 PM   #5
Glenn Hayes
I wish you The Best!
Enjoy yourself and have fun.
Old 03-08-2014, 12:13 AM   #6
Tom Moock
Liked 10 Times in 6 Posts
philbilly, good luck at sgmp, be careful doing your burnout when come out of the water, don't over rev your motor or you will bend your valves, it's easy to bend them, I'd try 6200 shift point, if you stay in low gear to long you will fill the car slow down. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 03-08-2014, 01:27 PM   #7
philbilly
philbilly's Avatar
Well I ain't sick! I shifted at 6 have 7 quarts of oil in. We landed a 12.54 on the first run. I don't want to try anything now because it's gonna be race time. Hopefully it will repeat some numbers and we will get they day one.
