Old 03-08-2014, 09:17 PM   #1
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Default Re: '67 Camaro E/SA redo
It may have taken out the sprag..... possibly...
Old 03-09-2014, 08:11 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
A bad converter would not act like the tires spun....it would act more like you left in second gear...They tend to lose stall speed and get tight and make a car leave very lazy.....
That Dexron VI fluid should not be an issue
When I had a Metric trans I did burnouts starting in 2nd and quickly shifted to 3rd...but that should not really be a cause for a problem.
Sounds like the trans may have lost first gear....or fluid level is low...
Does the ATF fluid look clean and the same color as it was....?
Any slippage in a trans quickly turns the fluid dark and may smell burnt...
Rich Biebel
S/C 1479
Stock 147R
Old 03-09-2014, 05:34 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Pulled it this morning Rich. Fluid looks as new with no burnt smell at all. Pulled the pan and there is a small amount of metal shavings. I'll take it to Arnett in the morning and let him diagnose/repair. Think I will replace the back u-joint while it's out...took a pretty good beating last week. I'm also carrying the convertor with me in case Thomas thinks a flush is in order.
Rich Taylor
I/SA - 321
