Old 07-16-2014, 10:17 PM   #1
Don Higgins
Default Re: Time vs RPM?
Originally Posted by Straightliner View Post
When you say *numbers* in the timer is that thousandths? I'm still on Crew Chief default ratios/factors. Because my car is heavy and only a 10.40 car I have been advised by most t-stop guys to go on and come off in low gear. Don is my logic correct in regards to the time shift that matches when it gets to 6500? If I should call you instead what is a good time for you?
Thanks
Brad in Canada!
OK, well that changes things a bit. Lets go over the basics of a throttle stop movement. It takes close to .40 seconds to open and close a throttle stop on average. That means you basically have .40 seconds of your stop timer that is wasted ( .20 to close, .20 to open ). So anything under .80 of a second in stop isn't doing much to your ET, at least not consistently. Not thousandths, hundredths.
You may need to shift on RPM in order to get some timer. You may also need to be on the first timer far longer than someone who runs quicker.
I believe the best way to find out is to test. 5 - 8 runs trying to make sure you can get to the 10.90 index with at least ONE SECOND of timer. If you can't do that with your current setup then bring #1 timer longer by .20 at a time until you can.
No magic unfortunately, every car is different.
Call us after you make a few passes that get to your goal.
Don Higgins - Super Comp #360H
Don Higgins is offline   Reply With Quote
Old 07-17-2014, 09:35 AM   #2
Straightliner
Okay. I will try and get some data next weekend. Thank you Don.
Brad
Straightliner is offline   Reply With Quote
Old 07-19-2014, 03:12 PM   #3
Straightliner
Hi Don, While waiting to get back to the track I realized I didn't give you my current numbers. Last event- bracket racing on the stop, so I wasn't changing timers just dialing the car accordingly (because I wanted to go rounds, not test during an event)
Timer one on at .500 and timer 2 set at 1.667 still in low gear, and shifting to high at 6500 rpm this had my car going 10.69 and repeating. If that helps you help me!!!
I'm still having a little trouble understanding the calculate ratios I just get a lot of negative numbers so I have yet to change from your program defaults. I have watched the video many times trying to grasp it, lol.
Brad
Old 07-20-2014, 02:13 AM   #4
Don Higgins
If you are trying to get a throttle stop ratio then you will need to change the throttle stop to get it to do anything.
If you are doing weather ratios then negative numbers usually mean the fuel type is alcohol and it runs better in worse air. Negative numbers on a gas car are a sign the mixture is too lean.
Old 07-23-2014, 04:39 PM   #5
Straightliner
Don or others can I get your opinion on 1 part of my post?
What I want to know is can I shift on time at the time it hits 6500 knowing that depending on timer 2 number that time would in fact be changing but I wouldn't actually change it to compensate it would just be what it is. Can I do it and be consistent? My thinking is that the time it takes to get to 6500 is also a changing time due to the timer 2 number.
Old 07-25-2014, 11:36 PM   #6
hookdaddy
Liked 8 Times in 3 Posts
Just curious, what is your cruise rpm set at? Raising the cruise will cause you to need more timer.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 07-28-2014, 11:29 AM   #7
Straightliner
4400 rpm on the playback tach.
