Old 08-22-2014, 02:02 PM   #4
rick lester
Liked 4 Times in 1 Post
Default Re: front anti-sway bar
Larry, I would think that would be more of a spring/shock issue, not a swaybar issue. Would a swaybar help, maybe but not as much as you would hope it would. It is worth trying, at least to say you did try it. Remember, that swaybar may be helping you with side wind downtrack is not helping you off the line at all. A rear sway bar is not used for sway per say, it helps more in keeping the rear suspension square which does help it from swaying going down the track but more for helping with the launch. If you are adiment about a swaybar, call what shock/spring man. you are going to run and ask there opinion/recommendations.
rick lester is offline   Reply With Quote
