Old 11-18-2014, 11:20 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
Hobbies and sports have great value, drag racing being a good example.
As the Super 10 project evolves the value is becoming identified by contacts made and lessons learned. Skills developed, ideas tested, plans scrapped, tubing cut in small pieces on the floor. Plans changed and progress made.
This week I ordered pistons, rings, pins, and block. Gary Hettler is beyond helpful and beyond kind. I bought heads from Gene Adams ,[another Gentleman] who's heads were at Gary Hettlers shop and had been on the shelf for a while as Gene made plans about another project.
We worked a deal, I bought the heads from Gene and made a deal with Gary to work over and update. In addition, work an intake for the combination.
Gary has taken me under his wing and is helping with the Super 10 combination like it was his own project. His advice and counsel carry's high value.
I called him asking for his suggestions about pistons and ring pack. After we talked a few min Gary said, "I will make two calls and get the order placed to my specs."
Man O man, drag racing is the real thing! It's value and passion covers the US from coast to coast with a common thread. Good men joined in a good sport. Gives me a smile.
Larry Woodfin 471W
Old 11-18-2014, 11:36 PM   #2
Dragsinger
I selected a Dart SHP "Pro Series" block. It has advantages I like. About 15 pounds lighter than a little M, uses BBC cam core, has .904 lifter bore and plenty of metal to allow + .060 bore without compromise.
With a 4.060 bore and +.013 stroke we have 338 inches of screaming Super 10 power! Even another smile at the thought.
Larry Woodfin 471W
Old 11-19-2014, 12:29 AM   #3
Little Chief
Larry, really excited for you, I know when I get a load of parts in it's like Santa came early. Hopefully those parts from Strange weren't packaged like the headers in which case you will need about a weeks rest.
Little Chief is offline   Reply With Quote
Old 11-19-2014, 12:52 AM   #4
Dragsinger
Chief, only took a few mins. Those Strange Engineering folks are tidy with packaging. Most likely they have many each day so must work quickly.
Larry Woodfin 471W
Old 11-22-2014, 09:52 PM   #5
Dragsinger
Some good Saturday progress.
First photos shows my custom housing adjustable struts. I like the adjustability. It allows slightly tweaking the housing alignment as the bearing ends are welded.
Just an 1/8 turn one way or other allows keeping the setup bar completely free.
Also, at final assembly it will be locked down just past handy to help maintain a straight housing.
Larry Woodfin 471W
Old 11-22-2014, 09:57 PM   #6
Dragsinger
More Saturday notes;
*Trusty level always near by
*alignment bar at work
*adjustable housing struts keeping the alignment bar free
ID:	26415   Click image for larger version
ID:	26414   Click image for larger version
Larry Woodfin 471W
Old 11-22-2014, 10:01 PM   #7
Dragsinger
My mock up of housing to frame to tire sidewall clearance called for 37 1/2" axle flange to axle flange.
The tape shows 37 1/2" right on the money I like it when a plan comes together.
Larry Woodfin 471W
