Old 01-02-2015, 11:17 PM   #31
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
some days bring only small progress, but any progress is good progress. This is a 3/16" thick aluminum plate custom built to mount the Strange master cylinder. On the back side is the reinforcing plate that Strange ships with the master cylinder.
All four bolts go into the factory brake booster mounting plate/column mounting fixture which a welded part of the body.
Tomorrow I expect to install/setup the 6.0 12 bolt gear and complete the axle/brakes assembly. In addition, I expect to build battery mount, cell mount and mount the air armed compressor
Larry Woodfin 471W
