Old 02-09-2015, 03:07 PM   #1
njk53
Default Gear Lube Level
Does the level of gear lube in a rear end have any effect on performance? If the gear lube level is filled to the bottom of the fill plug, can or does windage come into play creating performance losses?
If so, on a 12 bolt Chevrolet how much lube should be used and/or where should the level be relative to the ring and pinion?
Nelson Kowal
Stock 345
Old 02-09-2015, 04:29 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Gear Lube Level
Don't know if you will get a definitive answer on this...I've always ran 2 quarts in a 12-bolt without any bearing failures.
http://classracer.com/classforum/sho...gear+oil+level
Rich Taylor
I/SA - 321
Old 02-09-2015, 04:42 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Nelson,
From personal experience with 12 bolt, 1.5 quarts running mid 9's at 3100 pounds. No problems using Lucas 80/90 [Lucas #10043] conventional gear oil.
This is also what I will do with my upcoming build of the Super 10
Larry Woodfin 471W
Old 02-09-2015, 05:27 PM   #4
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
FWIW - I have always run 1 - 1.25 quart of 80-90 synthetic Lucas or Valvoline. If the rear end if completely dry - I use 1.5 qt. There was a thread on here a while back - and the opinions and experiences varied. The only other thing, I remember reading on the MW site years ago that they didn't favour synthetic. When I used dinosaur oil, I had no different experience, except cold mornings.
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 02-09-2015, 06:40 PM   #5
Lou Jeffery
In a Drag car that is only run for short distance you can safely get away with very little amounts of gear oil. Keep in mind the differential bearings and axle bearings rotate at a relatively low rpm. The pinion bearings rotate at close to engine speed at the finish line but they are force fed gear oil by the pumping action of the ring gear. So as long as you have enough oil for the ring gear to dig into you will not have problems. My 8.8 Ford axles that are very similar to a 12 bolt GM use no more 1.5 quarts.
Lou Jeffery is offline   Reply With Quote
Old 02-09-2015, 09:44 PM   #6
ghost
Liked 16 Times in 11 Posts
In drag only, with spool 10 sec car, I run 1.5 motor oil 10w40. Next step ATF oil. Reason... less difference between the run (cold) and (hot). Never broke the gear.
ghost is offline   Reply With Quote
Old 02-09-2015, 10:02 PM   #7
FED 387
Liked 333 Times in 180 Posts
We run John Deere TDH winter blend - bout a
"Large quart"-- 9 inch Ford-----so far so good ---Comp Eliminator car 8:00 @ 160MPH
Old 02-09-2015, 10:15 PM   #8
Ed Wright
Ed Wright's Avatar
Guys that know him, might want to talk to Jimmy Bridges about this.
Ed Wright 4156 SS/JA
Old 02-09-2015, 10:35 PM   #9
HandOverFist
Remember what I said about a definitive answer? I really think I would be looking elsewhere for gains.
Rich Taylor
I/SA - 321
Old 02-10-2015, 12:11 AM   #10
Liked 1,892 Times in 423 Posts
SHHHHHHHH!
