Old 02-19-2015, 11:34 AM   #2
njk53
Default Re: Trans cooler hose
Originally Posted by buzzinhalfdozen View Post
What's the best hose to use for tranny cooler? Looking at the Jiffy-tite fittings for trans but having a hard time nailing down exactly what hose to use. Most say they will work but I know a lot of hose gets very hard when running certain fluids thru them. Thanks Joe
We use Jiffy-Tite quick connects on our inlet/outlet transmission lines. We use braided steel lines from the transmission to the in-tank cooler in the radiator which makes it real easy to route. The Jiffy-Tite quick connects are a good product and work well to eliminate the mess when you have to pull your transmission. I think Jiffy-Tite may even make a transmission kit where you get the quick connects as well as 2 braided steel whips to install to the transmission. All you have to do is provide the steel braided line to route from the whips to and from your cooler. If you need further info, send me a PM.
Nelson Kowal
Stock 345
