Old 03-13-2015, 12:56 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ford vs Chevy Build-up
Just some leftover paint I had from the trunk.
Rich Taylor
I/SA - 321
Old 03-13-2015, 03:32 PM   #2
HandOverFist
Due to looming time constraints and the seemingly lack of C4 cores I bought a race ready C4 from Dynamic Transmission in Conn. It will be a fwd manual valve body, rollerized and equipped with a 2.90 gearset.
Had I known it was going to be such a problem locating a core I would have began my search much earlier. When Arnett told me he had not located one I knew I was in trouble. I'll still get Thomas to build one if a core ever materializes for a spare. All I need now is to get a convertor spec'd by ATI or someone else.
Rich Taylor
I/SA - 321
Old 03-13-2015, 07:04 PM   #3
SSGT Mustang
Liked 204 Times in 54 Posts
I probably should have mentioned this earlier, but I didn't know that you were in the market for a built C4 instead of just a core.
Ed Horensky who I believe is a member of this site is very, very knowledgable about C4's. I highly recommend that you look him up.
I sent the C4 in my Super Stocker to Dynamic for a rebuild. They did a very nice job, and seemed to have worked out some longstanding problems that I had with the trans brake. They are a good shop, and I'm sure that you'll be happy with them. I still would strongly recommend that you talk to Ed. He has information about many things that will be helpful to you.
I used JPT converters for a long time, but switched to Coan when Jim retired. I'm very pleased with Coan for many reasons. Excellent shop.
Several guys I know switched from other converter builders to Ultimate and picked up. You may want to give them a call, or Coan.
Nothing against ATI, but they would not be my first choice for a C4.
SSGT Mustang is offline   Reply With Quote
Old 03-13-2015, 07:18 PM   #4
HandOverFist
I wasnt in the market for a built trans until recently when I realized a waiting on a suitable core was going to seriously put me behind. I would be interested in other's experiences with different convertors...this is not set in concrete yet.
Rich Taylor
I/SA - 321
Old 03-13-2015, 08:30 PM   #5
partsbob67
Liked 79 Times in 11 Posts
is that spacer legal between the manifold halves?
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 03-13-2015, 08:39 PM   #6
HandOverFist
Likely not...I have that almost sorted out.
Rich Taylor
I/SA - 321
Old 03-13-2015, 08:41 PM   #7
7423
Good eye Bob............
7423 is offline   Reply With Quote
Old 03-14-2015, 11:27 AM   #8
partsbob67
i see. very nice build.
bob beals 7244
Old 03-15-2015, 11:19 AM   #9
SSGT Mustang
You may want to consider a C5 core. It's a later version of the C4 with an improved case. The band adjusters are metric, I believe, with fine threads. It also has better fluid passages. You would need to change the bell housing to a C4 housing since the converters are different. But, they are nice transmissions, and worth a look. I believe that everything else in them is C4 (I can double check for you).
Some builders prefer the C4 by default because from what I can gather they are just used to building them. But, again, there's really no difference between a C4 and C5 other than some case improvements. From what I see the C5 seems to be a better transmission. I'm building a K/SA for my son, and will be using one.
Follow up: There may be some other differences. Going out for the day, but I'll take a closer look when I get back. Nevertheless, you should look into them.
Old 03-15-2015, 12:14 PM   #10
fordteacherguy
Liked 160 Times in 51 Posts
C5's have a deeper bellhousing due to the deeper lock up converter they used, but have a improved oiling system that is a plus.The valve body is unique and is usually traded out for a C-4 valve body. Front band adjuster is a fine thread that is a 2:1 ratio to a stock C-4 course thread so you have to double your band clearance turns to 3 turns instead of the usual 1 1/2 turns. They are good cores to use if you swap the bellhousing for a C-4.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
